| REW Forum Penngray's HT room projectDiscuss Penngray's HT room project in the Subwoofer Equalization | Calibration forum; Penngray's HT room project Im going to use this thread to get all my questions answered and to post updates of doing full room ... |
| | #1 (Link) | |||
| Penngray's HT room project Im going to use this thread to get all my questions answered and to post updates of doing full room analysis of my new HT room. The room is ready for acoustical treatment but I want to run initial charts just so I know what Im starting with. Its a 13x25 room but the sound is on the 25 foot wall, I have run my theater sideways actually for many different reasons, I know already its not optimal and I need to really absorb reflections on the "back" wall because I have one row and it is 2 feet of the back wall. I will post pics and graphs as I go along. Anyways, here is the Equipment.... Nady CM-100 condensing mic, I assuming its identical to the Behringer brand so I will use the same cal. file Xenyx 1002Fx pre-amp HP Notebook with Vista soundblaster live! 24bit external USB Note: IF I can get his all done in 7 days I can return all the equipment ![]() | |||
| | #2 (Link) | |||
| Re: Penngray's HT room project I have connected all equipment according to the pics and posts on here. I have added the Behringer cal. file to calibrate the mic, should I have c Weighted SPL meter checked for this mic? and now Im trying to calibrate REW but Im stuck. I have read many threads, help files and they all talk about changing the REW input volume. Those options are greyed out. I can not change them...what can I do? I selected the proper soundblaster USB options in my My input and output device selections but what else? | |||
| | #3 (Link) | |||
| Re: Penngray's HT room project Here is the Mic/meter tab... ![]() here is the soundcard tab ![]() So far Im stumped on how to calibrate...I have the left main speaker out connect to the left line in to do the loop testing (although I can not tell left and right when looking at the 1/8" plug y-splitter that splits into 2 RCA connections. Here is what I get when I start measuring.... ![]() Here is what I get when I start the sound card calibration, I can not get even close to a 3 dB differential????? ![]() Its all very confusing but it doesnt seem that Im doing this correctly. I do get a signal on the left channel, not shown in the last pic, its gets up too -14 which is green but the message still says my DB is too low...is it thinking I need the right channel? ![]() Maybe its a Right and left thing ? I did switch input channel to Left and clicked "OFF" the use Left channel. I get a better headroom of 19dB but there is still a message talking about 10 dB. I guess my questions are.... What did I do wrong? | |||
| | #4 (Link) | |||
| Re: Penngray's HT room project EDITED: There is a phones/control room nob that I had set to zero......hang on.....I see dB levels now.... btw, 75 dB is pretty low to hear...should it be? Well, I still dont have a clue so I will wait for some help. Its hard to know if Im doing anything right, the numbers are all over the place it seems to me. Its kind of a crap shoot if you have never done this before. ![]() Note: this isnt a very active site is it? I hang on AVSForum and there is a tons of activity, help, opinion. I will be patience ![]() Last edited by penngray; 05-15-08 at 04:01 PM. | |||
| | #5 (Link) | |||
| Re: Penngray's HT room project The SB Live! 24-bit external seems very problematic under Vista, I don't think anyone has had good results with it. To check the volume settings, when you have REW running right click the volume control icon in the taskbar, select Open Volume Mixer and set the level for REW to the maximum. Close the volume mixer, right click the icon again and select recording devices. Double-click the Soundblaster Live Line In/Mic-In entry on the Recording tab that appears, select the Levels tab and put the Line In level to max. On the advanced tab set the sample rate and bit depth for shared mode to 2 channel, 16 bit, 48000 Hz (DVD Quality). | |||
| | #6 (Link) | |||
| Re: Penngray's HT room project Uncheck the Use Left Channel Calibration reference, since you're not using it. This is explained in the REW HELP FILES under Calibrating the soundcard and under Soundcard connections You are using the soundcard cal file method of calibration, so you will use the looped cabled during calibration to create your soundcard file and then store it and load it into REW. Then you'll remove the looped cable and your ready to go and hook up your cables. With an ECM8000 type cal file, the C-Weight check box doesn't have any effect. There are some reported problems with that soundcard and VISTA... brucek | |||
| | #7 (Link) | |||
| Re: Penngray's HT room project thanks, Im going to move the sound card to my desktop which is running XP. I will do a test there and see if I can get better results. I seem to be getting the Mic calibrated but I can never get it to match my RS SPL.... Example, I set my receiver volume so that my RS SPL shows 75 dB then I press calibrate on the mic, it comes up with a value I should enter on the screen the default is 75 dB so I assume I just press enter to calibrate. Then after that I look at the SPL meter and its reading about 10 to 15 dB higher then my RS meter still I guess this could be still a Vista issue so I will test with my XP box first. | |||
| | #8 (Link) | ||||
| Re: Penngray's HT room project Quote:
| | #9 (Link) | |||
| Re: Penngray's HT room project Okay, I think Im getting somewhere on XP. Current Mic and sound card calibrations. ![]() To get no distortion I had to disconnect my RCA connection from my mic pre-amp...otherwise I was getting a huge distorted line for my soundcard calibration. I never read that in any the help docs I was just experimenting to try and get a decent plot. I might have missed that I had to disconnect it when doing my loop connection. so Im going to assume Im calibrated and Im going to play around with it now. | |||
| | #10 (Link) | |||
| Re: Penngray's HT room project Okay, so this is my first full 0 to 10K Hz measurement.... ![]() comments? This is a test in my office so I know its going to be a crazy bad plot. I just want to know that Im ready to move the equipment in the room. Im not confident that its running full sweeps (mains and sub) I assume it is but those big distorted part on the right side seems like its screwed up and not set right, it simply looks like its all sub... how can I make sure it runs a full sweep with all main speakers together? | |||
| | #11 (Link) | |||
| Re: Penngray's HT room project Use a vertical graph axis of 45dB-105dB and a horizontal graph axis starting at 15Hz for all graphs. This is set by clicking the Graph Limits icon on the REW screen. When displaying graphs higher than 200Hz, you may turn on the smoothing feature (1/3 octave). This removes the normal comb filtering you're experiencing in your graph. Your receiver must be in stereo mode so that only the mains and sub are on. These are the only channels you can test since REW is a mono signal. Try the sub alone first (by disconnectingthe mains wires) and measure to 200Hz and use a graph horizontal axis of 15Hz-200Hz. Then when you get a smooth response by moving the sub around, add the mains and adjust the level (it's obviously low right now). brucek | |||
| | #12 (Link) | ||||
![]() I checked my receiver AUX input, and the red side is what you need to use ![]() | ||||
| | #13 (Link) | ||||
| | #14 (Link) | ||||
If your receiver is in stereo mode and the mains are set to small, there will be a signal coming from the sub and the mains......... brucek | ||||
| | #15 (Link) | ||||
| | #17 (Link) | ||||
I do try and get everyone to read this thread before they buy any equipment and attempt to hook up REW. It explains all the equipment required, where to get it, how much it costs, and how to hook it up. Combine that with the REW Help files and that's all anyone needs to be an expert. brucek | ||||
| | #20 (Link) | |||
| Re: Penngray's HT room project I started my HT room measurements tonight (the room has no treatments yet) I had everything calibrated friday but now I get the below message... ![]() "impulse peak not were it should be" ??? I double checked all calibrations and things seem to be fine so I dont know. here is the filter adjusted plot.... ![]() Here is the measurement plot..... ![]() and here is the waterfall plot..... ![]() The real measurement plot looks better then the filterd plot, is this always true? Also, I can not get the waterfall to show anything past 90 Hz....besides that the waterfall for the low end looks pretty good so far, doesnt it? Of course now Im nervous because if its good then I have to believe I did something wrong! | |||
