REW crash to desktop when selecting input device - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss REW crash to desktop when selecting input device in the Subwoofer Equalization | Calibration forum; REW crash to desktop when selecting input device When I start REW with my Tascam US-122 plugged in, I get the following error: No input mixers available supporting ...
Old 04-12-08, 12:23 AM   #1 (Link)
Alias: germanicus
User: #19099
Since: Apr 2008
germanicus is offline
supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
If I click OK the program opens, but when I go to settings and look at input devices for 44.1kHz, I see four items in the pull-down list:
Default Device
MacOSX, Core...
blank
blank
("blank" means a blank line). Presumably the Tascam should be in one or both of the blank lines. Selecting the upper blank gives a javascript error or sometimes a crash; the lower one causes a crash.
This is a Macbook Pro running OSX 10.4.11. I've got the latest drivers for the Tascam.
Old 04-12-08, 02:19 AM   #2 (Link)
Alias: Steven
Loc: lake ozarks MO
thewire's Avatar
User: #9828
Since: Jun 2007
thewire is offline
Re: REW crash to desktop when selecting input device
Have you checked the Tascam is enabled under "Applications/Utilities/Audio Midi Setup"?
High Speed Cable/Dial Up User - Remodeling/Designing/Building
Old 04-12-08, 03:13 AM   #3 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Under 10.4 you need to set the sampling rate as 44.1kHz and select the default input and output. Only the on-board audio input is available to java apps like REW, you need 10.5 to get Apple's fix for that.
Old 04-12-08, 11:20 AM   #4 (Link)
Alias: germanicus
User: #19099
Since: Apr 2008
JohnM wrote: View Post
OK - I'll work around it. Thanks.
Similar Threads
Looking for Input - First Run at REW YW84U REW Forum 23 01-26-08 02:34 AM
Amp for desktop/computer system? warpdrive HiFi Audio Components 12 01-13-08 01:03 PM
REW using Mic input Blaser REW Forum 3 11-09-07 05:43 PM
Let's see your desktop... Sonnie Chat Box 37 08-01-07 01:35 AM
Problem settings input level in REW Julien43 REW Forum 8 12-20-06 11:47 PM
Mach 5 Audio
