| REW Forum REW crash to desktop when selecting input deviceDiscuss REW crash to desktop when selecting input device in the Subwoofer Equalization | Calibration forum; REW crash to desktop when selecting input device When I start REW with my Tascam US-122 plugged in, I get the following error:
No input mixers available
supporting ... |
| | #1 (Link) | |||
| REW crash to desktop when selecting input device When I start REW with my Tascam US-122 plugged in, I get the following error: No input mixers available supporting PCM_SIGNED 48000.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian If I click OK the program opens, but when I go to settings and look at input devices for 44.1kHz, I see four items in the pull-down list: Default Device MacOSX, Core... blank blank ("blank" means a blank line). Presumably the Tascam should be in one or both of the blank lines. Selecting the upper blank gives a javascript error or sometimes a crash; the lower one causes a crash. This is a Macbook Pro running OSX 10.4.11. I've got the latest drivers for the Tascam. | |||
| | #3 (Link) | |||
| Re: REW crash to desktop when selecting input device Under 10.4 you need to set the sampling rate as 44.1kHz and select the default input and output. Only the on-board audio input is available to java apps like REW, you need 10.5 to get Apple's fix for that. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Looking for Input - First Run at REW | YW84U | REW Forum | 23 | 01-26-08 02:34 AM |
| Amp for desktop/computer system? | warpdrive | HiFi Audio Components | 12 | 01-13-08 01:03 PM |
| REW using Mic input | Blaser | REW Forum | 3 | 11-09-07 05:43 PM |
| Let's see your desktop... | Sonnie | Chat Box | 37 | 08-01-07 01:35 AM |
| Problem settings input level in REW | Julien43 | REW Forum | 8 | 12-20-06 11:47 PM |
