more than 12 filters possible? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss more than 12 filters possible? in the Subwoofer Equalization | Calibration forum; more than 12 filters possible? Is there any way to increase the number of filters available? I'm experimenting with using REW to equalize my full-range ...
Old 04-11-08, 10:09 AM   #1 (Link)
Alias: germanicus
User: #19099
Since: Apr 2008
germanicus is offline
Is there any way to increase the number of filters available? I'm experimenting with using REW to equalize my full-range speakers, and 12 filters isn't quite enough.
More generally, have others had success using REW with full range speaks? Sorry if that's a stupid question - I've been using drc until now and am completely new to this program. So far the results seem to be good, and the GUI makes a huge difference!
Old 04-11-08, 10:36 AM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: more than 12 filters possible?
Welcome to the Forum, germanicus!
No, there is no way to add more filters to an equalizer than what it has, any more than it's possible to add additional loading drawers to your DVD player. If you need more you might try a 1/3-octave equalizer - they have about 30 filters per channel, but they are all at fixed frequencies and bandwidth, not parametric like the BFD (I assume that's what you're using?).
I'd suggest that you're probably over-equalizing, 'cause 12 parametric filters is quite a few even for full-range equalizing.
Old 04-11-08, 11:02 AM   #3 (Link)
Alias: germanicus
User: #19099
Since: Apr 2008
Thanks!
Sorry - I didn't ask my question very clearly. I mean in REW - when I open the EQ Filters table in REW, there are only 12 filters available. I was wondering if it's possible to increase that number.
I'm not using an equalizer - I'm using a PC based convolver (the Inguz plugin for slimserver). So I've been experimenting with using REW to produce a filter impulse response, which I then export as a WAV file and feed to Inguz. AFAIK there isn't any theoretical limit on how many filters it's possible to apply in the process of producing that impulse response.
You're probably right - I'm pretty new to this, and very much at the experimentation and learning stage.
Using the 12 filters, I can get the corrected curve flat to within +-3 dB from 24Hz-20kHz, which is decent. This weekend I'm going to take some measurements and see how close to reality that actually is. I'm also disobeying the rules and trying to correct for nulls - if I didn't do that, I'd have more filters available. I'm curious to see if it works. It probably won't.
Old 04-11-08, 12:24 PM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Gotcha. You must be using the BFD 1124 setting. Under the "Equalizer" tab top left of screen) change the setting to "Generic," and you'll have 20 filters. That should do ya!
Not all dips in response are nulls - see here.
Old 04-12-08, 11:49 AM   #5 (Link)
Alias: germanicus
User: #19099
Since: Apr 2008
Great - thanks! I hadn't noticed that.
I've just created a very nice full-range filter, throwing caution to the wind and using all 20 filters. It sounds pretty good, actually. The bass is much better. It's not so clear to me that the treble equalization had a definite positive effect, but I want to listen for a while longer before I decide anything.
Similar Threads
BFD keeps applying more filters ? Ashmanuk BFD Forum 7 05-19-08 07:40 PM
Tried using fewer filters, here are the results clausdk REW Forum 5 01-29-08 03:03 PM
Nubee need help w/ eq filters miltcharlie BFD Forum 1 12-30-07 09:00 AM
Adding EQ filters for my EQ legierk BFD Forum 5 04-16-07 04:24 PM
Filters only above 100hz sammythebu11 REW Forum 1 11-18-06 05:39 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
