rew help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
rew help
Discuss rew help in the Subwoofer Equalization | Calibration forum; rew help hi this is my first attempt at rew just got a new sub sb12+ sounds great to me but what ...
Old 04-13-08, 12:57 PM   #1 (Link)
New Member
Alias: tevez
Loc: essex
User: #19242
Since: Apr 2008
tevez is offline
rew help
hi this is my first attempt at rew just got a new sub sb12+ sounds great to me but what it looks like i have not got a clue so any help would be much appreciated thanks.
sub only
sub and fronts
Old 04-13-08, 01:10 PM   #2 (Link)
Alias: Tim
Loc: North of Atlanta, GA
OvalNut's Avatar
User: #1625
OvalNut is offline
Re: rew help
Do you have the SPL meter calibration file loaded, and what SPL meter/mic are you using?
Just checking to make sure the SPL meter calibration file was loaded before you took those sweep measurements. It kinda looks like it wasn't.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
Old 04-13-08, 01:52 PM   #3 (Link)
New Member
Alias: tevez
Loc: essex
User: #19242
Since: Apr 2008
tevez is offline
Re: rew help
thanks for your quick reply it was loaded i just un-ticked the box. spl meter Model 33-4050 radio shack.
where am i going wrong.
Old 04-13-08, 03:04 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Re: rew help
You're not. Why do you think you are?
BTW, use the standard graph axis we use here at the Shack which is vertical axis = 45dB-105dB and horizontal axis = 15Hz-200Hz.
Old 04-13-08, 03:12 PM   #5 (Link)
Alias: Tim
OvalNut's Avatar
User: #1625
OvalNut is offline
Re: rew help
I think the question he has is why does the rolloff of the sub not more closely match the rolloff shown in the target line. My initial thought before EQing this sub would be to either raise the sub level/volume and remeasure, or lower the target line some. This will give you some headroom for the cuts needed to then EQ down to the target line.
Tim
Mach 5 Audio
