Finding Peaks - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Finding Peaks
Discuss Finding Peaks in the Subwoofer Equalization | Calibration forum; Finding Peaks Hello, seems that it is not possible to use this function over 500Hz (i intend to do measurements on the ...
Old 04-14-08, 09:43 AM   #1 (Link)
Alias: cedric
User: #18117
Since: Mar 2008
fouiz is offline
Finding Peaks
Hello,
seems that it is not possible to use this function over 500Hz (i intend to do measurements on the full range to set up a DEQ2496).
correct ?
Old 04-14-08, 10:21 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Finding Peaks
The find peaks function is designed to create filters to cancel modal resonances. They simply don't exist over 500Hz.
There is nothing stopping you from entering your own manual filters into REW though. Be sure that any filters at those higher frequencies have a low Q or you'll be wasting your time.
Old 04-14-08, 10:32 AM   #3 (Link)
Alias: cedric
User: #18117
Since: Mar 2008
fouiz is offline
Re: Finding Peaks
brucek wrote: View Post
OK for the modal resonances.
Now, can you be more precise about the Q setting ?
Old 04-14-08, 10:47 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Finding Peaks
When you take a full range measure you will see a very jagged looking response when the frequency gets above 500Hz. In fact it often looks so bad, many think they've made a mistake. They haven't. The jaggedness is a result of comb filtering reflections.
To get a better feel for the underlying trend of the signal (and to come a little closer to how we actually hear) you need to turn on smoothing feature. Use 1/6th or 1/3rd octave smoothing. (remember, smoothing is not for low frequency measurements as it would obscure the true shape of the response and so not allow accurate correction filters to be determined).
Now you can see the response much better when the smoothing is on. This also reveals that it would be pretty silly to start using narrow bandwidth (high Q) filtering. You really need to use the type of filter a typical equalizer would provide (i.e. low Q, 1/3 octave or greater).
Old 04-15-08, 10:20 AM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Finding Peaks
fouiz wrote: View Post
Hello,
correct ?
Here's a thread on full-range EQ project that one of our members embarked on a few months ago - you mght find some good info in it.
http://www.hometheatershack.com/foru...ase-chime.html
Old 04-15-08, 11:23 AM   #6 (Link)
Alias: cedric
User: #18117
Since: Mar 2008
fouiz is offline
Re: Finding Peaks
Thanks Wayne.
Don't you think it would be useful to split the forum in two parts : one for sub eq and another one for full range eq ?
Because it seems to me that REW can be usefull for both and not only subs ...
Old 04-15-08, 12:03 PM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Re: Finding Peaks
Absolutely REW is useful for both! We see very few people attempting full-range equalization, though - not enough to justify a separate Forum. Spridle was the last one I know of who opened a thread on the topic (the link above), and as you can see that was over five months ago.
Old 04-15-08, 03:42 PM   #8 (Link)
Alias: cedric
User: #18117
Since: Mar 2008
fouiz is offline
Re: Finding Peaks
OK, so, i'll be next !
I'll try yo post every action since now, as i'm really starting to work on it now, and still discovering the soft.
I'll need help, though, as i'm not familiar with acoustics, and not that good in english too.
Hope you masters of the forum have a little time to light the trail !
Old 04-15-08, 04:30 PM   #9 (Link)
Alias: germanicus
User: #19099
Since: Apr 2008
germanicus is offline
Re: Finding Peaks
I'm experimenting with equalizing my full-range speakers using the Inguz plugin for Slimserver (my source is a squeezebox 3). I'd been using the program drc to generate the correction filters, but I'm finding that the filters I make with REW give results that are at least as good, and it's much easier to adjust and check results with it.
Without knowing very well what I was doing I seem to have fallen into the good practices described in the thread linked to above - that is, I'm using pretty broad filters at high frequencies, since I quickly discovered the futility of trying to get rid of every peak. The improvement is greatest in the bass, but I've found the mid and treble are improved too (which I think is more a question of achieving the balance I like best than of equalizing to a flat response).
I'm curious to learn more about the differences between drc and REW. The algorithm drc uses to generate correction filters is much more complex than just adding some peak filters - it does fancy things with phase, for example. But in the end the results don't seem to be audibly better. Still, I wonder what a program combining the ease of use of REW and the horsepower of drc might be able to do.
At the moment things are stalled while I wait for a longer mic cable to arrive (as things are now the measurement process is a real pain, and the cable will make it much easier). I'll report back when I've made some more progress.
Similar Threads
Finding a replacement bulb... Sonnie Manufacturers Service and Support 4 01-25-08 11:33 PM
Finding Neverland nova Movies | TV Shows | Hollywood 2 06-01-07 05:04 PM
Help finding a sub. mgboy DIY Subwoofers 9 04-24-07 07:49 AM
No peaks to correct, but they are there! frank308 REW Forum 13 03-01-07 07:18 AM
reducing peaks question.. tdamocles REW Forum 5 12-02-06 04:55 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
