Correcting w/ Alesis M-EQ 230 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Correcting w/ Alesis M-EQ 230 in the Subwoofer Equalization | Calibration forum; Correcting w/ Alesis M-EQ 230 Ok, my first post.... here it goes. I've been using an Alesis M-EQ 230 for correction since I was 18 ...
Old 04-20-08, 09:31 PM   #1 (Link)
New Member
Alias: Travis
Loc: Twin Falls, ID
User: #19847
Since: Apr 2008
inivid is offline
I've been using an Alesis M-EQ 230 for correction since I was 18 (I'm 27 now). It's been an excellent piece of hardware. It's a 2-channel (32 bands per channel) +/-12dB equalizer that I bought from Musician's Friend way back when. The system I'm correcting is a simple 2.1 system that I've had for just as long, although the mains have since been upgraded. I'm more into music than I am into movies, thus the simple system.
I've read through the Help file and am curious if there is anything additional I need to know, or that would be helpful, in using REW to correct my system.
Additionally, I have been using a Radio Shack 33-4050, for a meter and mic, since 2004. Also a great tool.
-Travis
Old 04-20-08, 10:02 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Correcting w/ Alesis M-EQ 230
Your multi-band equalizer is fine for broad correction of your mains, but you really require parametric control over filters to shape them as cancellers of modal resonances (< 200Hz).
For that you would require a parametric equalizer.
Similar Threads
So I can pick up a couple new tc-3000 15's for $230 each, should I Giyan DIY Subwoofers 5 12-30-07 05:39 PM
Any special considerations when correcting low end of full range signel?? Julien43 BFD Forum 1 12-20-06 11:36 PM
Is the 1124 sold in the U.S. capable of running on 230/240v? Gard BFD Forum 5 10-24-06 04:08 PM
Mach 5 Audio
