| REW Forum Do i need anything else?Discuss Do i need anything else? in the Equalization | Calibration forum; Do i need anything else? Hi, hope i have posted in the correct place, if not i apologise.
Stumbled across this page while reading in ... |
Views: 554 - Replies: 19
| Do i need anything else? Hi, hope i have posted in the correct place, if not i apologise. Stumbled across this page while reading in another forum, which said i may not need a SPL meter. This sounded great as i dont have one, but i'm a little confused as to how i can use my microphones to take room measurments. Think i managed to do a soundcard loopback test, though not really sure what info i can gather from that. I have a M-Audio 2496 soundcard, Joemeek Sixq Preamp with S/pdif output, VTB-1 Preamp, Soundcraft Mixer for my analog outputs to feed my analog inputs on my soundcard. For microphones i have Shure SM58 Beta, JoeMeek's, Samson and SE Electronics SE200 Oh and for monitoring i have a pair of Yamaha MSP5. Will i be able to measure room EQ response with the above equipment? Many thanks | ||||
| | #2 | ||||
| Re: Do i need anything else? Your microphone will need a calibration file and you also need an SPL meter. Best to read The REW HELP FILES and this thread. brucek | ||||
| | #3 | ||||
| Re: Do i need anything else? Right, thanks for those. And after much......much reading i "think" i'm starting to understand this a little better. I'd just like to clarify a few things to make sure i do all this the right way. First things first, i'm using this for a home studio setup with No Sub, just stereo speakers, and i'd like to measure my room response so i can either use corrective EQ in my music software or buy acoustic panels to achieve the desired flat response! I see that i need the SPL meter to measure the 75db, as this seems quite hard to come by in the UK, other than ebay, is there another way to do this or a way to guess? I have succesfully done a soundcard Cal, but was wondering if i need to include my mixer (preamp) in these tests, or to wait until i use the mic. Also i plan to buy the ECM8000 to do my measurements as i cant find Cal files for any of my mics. Many thanks again for any help with these questions | ||||
| | #4 | |||||||
| Re: Do i need anything else? Quote:
After its set at a reasonable level, you click the REW SPL calibrate routine (which simply tells REW what your SPL meter is reading). You set that to 75dB. Yeah, maybe it's actually 79dB , but it is not too important. Quote:
The mic itself, of course, is compensated by the mic calibration file (which you load manually). I guess your listening position is the mixer chair position? brucek | |||||||
| | #5 | ||||||
| Re: Do i need anything else? Cheers for the clear and informative response brucek! ![]() Quote:
Also (sorry for all the questions btw) i have another preamp which connects digitally to my soundcard (S/pdif) i assume i cant test it this way though? Quote:
I should hopefully be picking up my ECM8000 Tomorrow so the testing can finally begin, and no doubt many more questions will follow! Thanks Again | ||||||
| | #6 | |||||||
BTW, it's very easy to create an REW calibration file for any studio mic you have, if you've got a response graph that came with it........ brucek | |||||||
| | #7 | ||||||
![]() Quote:
So i had a look into finding some graphs for my mics and came across 2, one for the SE2000 (condensor) and one for the Shure SM58 Beta (Dynamic) If you could please tell me which one would be better (if any) so i can have a look into making the Cal file. If none are ok, then i'll just get the ECM. SE2000: ![]() Shure SM58 Beta ![]() Cheers | ||||||
| | #8 | ||||
| Re: Do i need anything else? Yikes..... that SE2000 graph shows that this mic is a very capable unit. I wonder if the graph is accurate. Basically, that's a flat microphone.... from 20Hz to 20Khz It doesn't alter its output by more than ~3dB over that range. If true, you don't need a calibration file for that mic if you're using it with that bandwidth. It is simply flat. Forget the ECM8000 if you have a mic that is as accurate as the graph for the SE2000 shows. brucek | ||||
| | #9 | ||||
| Re: Do i need anything else? Super.... Thats great to hear ![]() Well i know it's quite a good mic for studio purposes, but didn't think it'd be any good for this type of work, so im over the moon you said that, saves me a few pennys anyways!! Couldn't tell you if the graph is 100% accurate myself, but i pulled the graph from thier website, and i remember seeing it in my manual aswell, though i cant for the life of me remember where i put it ![]() So i'm guessing i just follow the guide to do my tests, but don't load any Cal files for the mic? I shall try it anyways, and see what happens. I must thank you again for your time and patience in helping me out with this! No doubt i'll be posting graphs for this, so should i just post them here or start a new thread? Cheers | ||||
| | #11 | ||||
| Re: Do i need anything else? Right.... Had a feeling i may have some trouble with this. Tried some test's last night and this morning, and as you can probably tell from the graph below, something is not right, (as for one, they look nothing like anyone elses on the forum) though i'm not sure what i'm doing wrong?! Also should the test sound be only coming through one channel (in my case the left channel) so for eg... you test the left channel for one graph, and then do the right channel on another graph? Well here's the graph, hope i got the settings right for posting as i checked them with the thread you posted. Thanks Again ![]() | ||||
| | #12 | ||||
| Re: Do i need anything else? Your graph is quite normal, albeit measured at a slightly low level. Try to measure a bit higher next time and be sure to run the REW SPL Calibrate routine to set the 75dB into REW's SPL meter (after you've set your room level). Anyway, what looks like a horror show is actually comb filtering, which are reflections from the room's surfaces. When you measure full range, you need to apply smoothing after the measure is taken. Click the smoothing feature to about 1/3 octave, as this is more representative of how we actually hear. The jaggedness is really too narrow to be perceived, and so to reveal the underlying trend of the signal and to show if treatments are effective, you need the smoothing feature on. This is not the case for subwoofer measurements when creating filters for EQ's, but you're measuring full range. In that regard though, it wouldn't hurt you to take a look at the area from 50Hz-200Hz with simple axis change to your graph, so as to narrow in on any modal problems you may have to address (which hopefully would be solvable with positioning)..... brucek | ||||
| | #13 | ||||
| Re: Do i need anything else? Ok, thanks for that, and for the quick reply. I've had another go, hope this is the right loudness level as i am guessing: ![]() And the zoomed in version: ![]() Also this is for the left speaker out only, as no sound was coming from the right speaker. Looks like i have a good few dips and peaks though. | ||||
| | #14 | |||||
I guess I would look at both speakers individually, and then play them together (simply use a Y-adapter to feed both channels of the receiver). The REW signal is obviously mono, so looking at each speaker by itself will reveal any specific problems to that speaker, but you also want to see what it looks like when the two speakers play in concert. You have about ~ +/-5dB variation across the spectrum except for the <100Hz area. The dip at 70Hz and the peak at 60Hz will be noticable. It's also concerning that the signal drops off so rapidly above 10K. I wonder if this is the speakers or the microphone. You would need one of them swapped out with a "known" before you could determine that. I don't know if you've treated your studio area much, but I would say not considering the amount of relections you showed in the unsmoothed plot? To try and smooth the response, the RTA feature of REW is very handy. Use Periodic Pink noise with a Rectangular Window and maybe a 1/24 Octave RTA with 65536 FFT and then simply move around the mic and watch the screen. It may reveal a better listening position. Again, I'm not a studio guy, so I'm just guessing at this point. The guys in the Home Audio Acoustics section would know more about room treatment. brucek | |||||
| | #15 | ||||||||
| Re: Do i need anything else? Thanks for the reply, Quote:
A point on the unsmoothed plot....... if my room was treated, (the right way) would i not need to apply the 1/3 octave smoothing? Quote:
![]() Also before, i make a post in the Acoustics section, can i post a L/R and Stereo Graph of the measurements taken with a ECM (which will probably be tomorrow now as the shops have closed here ) just so i can have a professional opion on the problem areas!Cheers | ||||||||
| | #16 | |||||||
It ain't a bad idea to get the ECM. It's a good all round omni measurement microphone for a very decent price. They offer a fairly consistent response between units, so the cal file we have here will be fine.... If you want to get crazy, you can get it calibrated, but for home use, it's pretty good with the cal file we have. brucek | |||||||
| | #17 | ||||
| Re: Do i need anything else? Sorry for my delayed reply, seems as though the ECM Mic is very hard to come by in Birmingham But it finally arrived yesterday so i have had chance to take some more measurements.also in the time it has taken to arrive it has given me chance to build my acoustic panels which i am certain i will need ![]() Just want to make sure where my problems lie before installing all the panels. The following graphs are all stereo taken with the ECM mic, the 1st is the original Speaker Position (spread quite far L-R from the sweet spot) ![]() I thought the Speaker position may be spread too far so i brought them closer in and this was the result: ![]() I've aslo been doing a lot of reading on speaker decoupling and tried some foam underneath the speakers on this following graph: ![]() Hope this all kinda makes sense, and i know for certain i need some treatment but would you say the 3rd graph was the best of the 3? Thanks again for your help! | ||||
| | #18 | ||||
| Re: Do i need anything else? You would be much better off measuring each speaker individually rather than both at the same time. When both speakers are running any path length difference between the speakers and the mic results in comb filtering, just like the comb filtering that results from a reflection. If you use the "Measured" graph group your plots will all appear on one graph making it easier to see the differences between them. To evaluate the effects of acoustic panels the energy-time curves can be very useful, with the Y axis set to the "% FS" units, as it is easier to see the spikes after the main spike which are due to reflections from room surfaces and how effective panels at the reflection points are in reducing the levels of those spikes. | ||||
| | #19 | ||||
| Re: Do i need anything else? Ok, thanks for the info, i've had another go and as i have 2 sets of monitors i thought i would try both, so on the 1st graph i have grouped the tests for the left side, and then the right side for the 2nd graph. this test has been done with 9 acoustic panels set up in various positions throughout the room, though it does sound different in here, i never noticed much difference on the test i made, and i still had to apply the 1/3 octave smoothing. Is this normal? And as for the graphs of the 2 monitors which would you say is better and any ideas to further improve the 200hz down? Thanks again Yamaha L = RED Alesis L = Blue ![]() Yamaha R = Green Alesis R = Purple ![]() | ||||
| | #20 | ||||
| Re: Do i need anything else? It is normal to need smoothing for full range responses. The Alesis responses look better, much more even. You could use some EQ filters to even out the response below 200Hz and/or put in some fairly hefty bass trapping in the corners. The Home Audio Acoustics forum can offer plenty of advice on treatments. | ||||
