| REW Forum M-Audio FastTrack setup...Discuss M-Audio FastTrack setup... in the Subwoofer Equalization | Calibration forum; M-Audio FastTrack setup... Good day, I have searched for setup/calibration with this particular external soundcard. First off, i am completely new to ... |
| | #1 (Link) | |||
| M-Audio FastTrack setup... Good day, I have searched for setup/calibration with this particular external soundcard. First off, i am completely new to this, so i do apologize for the 'simple' questions. http://www.m-audio.com/images/global...k_back_RGB.jpg http://www.m-audio.com/images/global..._front_RGB.jpg Soundcard is an M-Audio FastTrack USB, running on a Mac with OS X. There is a line in on this unit, and RCA for output. While trying to calibrate this unit, i ran RCA's from the output to a 2 to 1 adapter, and into the line in. Played around with all the knobs etc, while trying to calibrate the soundcard, but to no avail. At the moment i dont have any charts to show (at work right now), but all of my measurements start from around 500hz, and are ranging in over 30db! So i know something is really wrong with my setup. Can anyone lead me in the right direction? I will try to post up a chart as soon as possible, but this is probably easily solveable. Thanks for your time! Darryl | |||
| | #7 (Link) | |||
| Re: M-Audio FastTrack setup... Ok, i got a couple charts, identical, but still two separate measurements. I am using leopard 10.5.2, so no issue there i hope. I connected m-audio fast track to usb on ibook. On the front panel, all dials turned up, and input monitor set to mono. Back panel, one rca connected to the right channel of the RCA outs, input level button set to line in, other end of rca connected to a two to one adapter running into the line in. Hope that sums everything up... In audio/midi settings i set sampling rate to 44.1hz, all my default inputs/output sounds on the system are set to run through the fasttrack. And lastly i have attached the settings i use in the sound card screen. Thank you all for your help! Darryl | |||
| | #10 (Link) | |||
| Re: M-Audio FastTrack setup... Well i searched my software, my audio settings in OS X, and looked for switches on my hardware, and could not find anything pertaining to input monitoring... Anyone have any other suggestions by chance? Thanks | |||
| | #11 (Link) | |||
| Re: M-Audio FastTrack setup... You could try turning the "Mix" knob all the way round to "Input" instead of to "playback" and see what effect that has. EDIT: Might be the opposite to what is wanted, the M-Audio knowledgebase may have more details on the effect of that knob. Also worth trying to get things running using the built-in audio I/O of the Mac. | |||
| | #13 (Link) | |||
| Re: M-Audio FastTrack setup... Looking at your original screen shot seems the input maybe on the left channel rather than the right, in which case the measurement is probably just crosstalk which is why it rolls off at the low end. If you swap to the other input channel on your 2 -> 1 adaptor all may spring into life. | |||
| Thread Tools | |
Similar Threads | ||||
| My Ht Setup | tomscave | Home Theater Gallery | 3 | 03-17-08 05:52 PM |
| Need smaller setup | fernalfers | Home Theater Seating and Accessories | 2 | 03-11-08 06:47 PM |
| My Setup | weeZ | Home Theater Gallery | 5 | 03-29-07 10:32 PM |
| M-Audio Fast Track Pro setup help | 737NG | REW Forum | 3 | 03-01-07 11:10 AM |
| M-Audio Basic Setup Question | rolyasm | REW Forum | 7 | 07-16-06 12:19 AM |
