REW on mac - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
REW on mac
Discuss REW on mac in the Subwoofer Equalization | Calibration forum; REW on mac i have been using this software for about a week on my intel mac core 2 duo. i have 2gig ...
Old 04-09-07, 10:00 PM   #1 (Link)
New Member
Alias: therecordinghouse
User: #7944
Since: Apr 2007
therecordinghouse is offline
REW on mac
i have been using this software for about a week on my intel mac core 2 duo. i have 2gig of ram. the program works for the most part but randomly crashes..just totally disappears, no error message or anything. anyone else using a mac that could help me out? btw, i am using java 5.
Old 07-27-07, 10:29 AM   #2 (Link)
New Member
Alias: zzzxxx
Loc: Santa Barbara
User: #3888
Since: Nov 2006
zzzxxx is offline
Re: REW on mac
I have been hopeful that REW would be successfully ported to the Mac for over a year now. Any possibility of this happening?
thanks,
Jack
Old 07-27-07, 04:53 PM   #3 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: REW on mac
I've made progress on porting to the Mac, fixed various rendering bugs that are unique to Aqua and several soundcard related issues, but still have a problem that JavaSound can only access the built-in audio input device regardless of what device is set as default in the System Settings (it will access whatever device is set as default for output though). The random crashes are happening inside the Apple Java Virtual Machine so nothing I can do about those - perhaps they will vanish when Leopard is released with Java 6. In the meantime the next time I make an REW release it will have all the workarounds I have included to cope with the Mac and it seems stable on the Intel Core Duo 1.83GHz Mac Mini I bought to check it on, running 1GB RAM. It is fairly frustrating since the whole point of Java is there should be no porting to do, it is supposed to be cross platform and the platform owner deals with all the platform-specific issues in their virtual machine implementation. Apple apparently don't see it that way, so if you want a Java audio app to run properly on a Mac you have to rewrite it to use their class libraries instead of the ones that are already part of core Java (which work just fine on PC, Linux and Solaris). I just don't have the time to rewrite all the audio handling to make a Mac-specific version, so live in hope that they can spare a few minutes from counting all the stacks of dollars from their iPhone booty to make their JVM do what it is supposed to.
Old 07-27-07, 07:44 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Re: REW on mac
$125 vs. $0 and a ton of free support from Shack members.
Old 04-24-08, 08:52 AM   #5 (Link)
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
mrsollars is offline
Re: REW on mac
i think he meant a ton of support for REW.
i'm a mac user as well....any troubles using REW through Parallels???
Similar Threads
REW Mac OS X problems bhunt REW Forum 15 03-10-08 02:17 PM
Mac revisited asherbro REW Forum 22 05-07-07 07:39 AM
REW crashing on Intel Mac - why? Tom Tripp REW Forum 1 10-22-06 05:48 AM
Intel/Mac, MIDI, and REW? Ross Winn REW Forum 5 09-04-06 12:04 PM
mac rew help ghozt REW Forum 1 06-11-06 12:43 PM
Mach 5 Audio
