Sweeps show a drastic rise. need help - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Sweeps show a drastic rise. need help in the Subwoofer Equalization | Calibration forum; Sweeps show a drastic rise. need help I've used REW for the past 3 years and haven't had an issue with it until now. The measurements that ...
Old 04-25-08, 04:16 PM   #1 (Link)
New Member
Alias: robby
Loc: I ain't tellin ya!
User: #696
robbyho is offline
The measurements that I took today all show a 20db rise during the course of the measurement along with the usual FR deviations that I would expect. It is as if the program or the sound card is measuring the response with some sort of weighting.
Any ideas as to what causes this? I've done it with two different laptops using the most recent version of REW. I've swapped sound cards, mics, cables, pre amps, and more with the same results. The sound settings on the computers seem ok.
This is a quick shot of what I mean. It is happening to all my measurements with the new version, not sure about the older versions.
Old 04-25-08, 05:08 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Sweeps show a drastic rise. need help
What does the scope look like?
Old 04-25-08, 07:47 PM   #3 (Link)
New Member
Alias: robby
User: #696
robbyho is offline
like this:
Old 04-26-08, 06:38 AM   #4 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Do you have a soundcard cal file loaded? If so, what does the soundcard cal response look like. If not and you are using the left channel as a reference input with a loopback make sure left & right are not swapped.
Similar Threads
How to do Continuous Sweeps a la SMS1 with REW? waffles REW Forum 4 03-31-08 06:44 AM
Ragged sweeps? dinotoad REW Forum 5 01-31-08 02:05 AM
Fantastic Four - Rise of the Silver Surfer Sonnie Movies | TV Shows | Hollywood 5 10-27-07 09:58 PM
use of multiple sweeps in measurement terry j REW Forum 3 09-15-07 04:48 AM
did sweeps - now what? cyberbri REW Forum 1 01-18-07 01:34 AM
Mach 5 Audio
