First sweeps with REW - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 01-16-15, 01:21 PM Thread Starter
finalrinse's Avatar
Finalrinse
I finally have my HT setup in my basement.
AVR - Denon x4000 with Audyssey XT32 with Sub EQ
Subs (2)HSU VTF-3MK4
Sub (1)HSU MBM-12 Mid Bass Module
Main speakers - (2)Klipsch RB81 II, Center (1)Klipsch RC62 II, (4)Surrounds - Polk in-ceiling 8"
- Left MK4 and MBM-12 on Y-Adapter to left sub output
- Right MK4 on right sub out (I tried the MK4's on one output and the MBM-12 on one but the way I have it seems better).
- Both MK4 subs located close to R and L main speakers and close to corners and equal distance from MLP
- MBM-12 located between subs centered in middle
- Both MK4's crossovers set to 50Hz
- MBM-12 crossover set to Out (50Hz to 150Hz)
- AVR crossovers set to 200Hz (tried 150Hz but graph is better at 200Hz and I think it sounds better)
I do have a MiniDSP Balanced 2x4 but have not hooked it in the system. Not sure how to best hook up the 3 subs if I do decide to use it?
What do you think and what would you do next if anything? I think it sounds good, but you know how that goes! All advice and comments are appreciated! I've been reading and waiting for years to properly use REW!
Audyssey ON and No smoothing
finalrinse is offline
post #2 of 11 Old 01-17-15, 06:42 AM
REW Author
JohnM's Avatar
John
Re: First sweeps with REW
Looks very good. Get a movie on!
JohnM is offline
post #3 of 11 Old 01-17-15, 07:54 AM
Talley's Avatar
JohnM wrote: View Post
Even though there are some hefty dips? Sorry, I'm not experienced yet so I'm still figuring it out but that dip at 54hz essentially is inaudible during listening. Some kind of cancellation going on yes?
How impossible is it to treat the room to get a no smoothing chart thats flatter with only +/- 3db?
Talley is offline
post #4 of 11 Old 01-17-15, 09:06 AM Thread Starter
finalrinse's Avatar
Finalrinse
Thanks John!
post #5 of 11 Old 01-17-15, 09:11 AM Thread Starter
finalrinse's Avatar
Finalrinse
Bmxer241 wrote: View Post
You just gave me an idea. My main sub-woofers crossovers are set to 50Hz (at least by the dial on the back, how accurate is the dial?) Maybe I should set the crossovers to 45Hz and try, just an idea as I realize the slopes overlap. If it is a cancellation or null I will work on possible slightly re-positioning.
And then of coarse I do have a MiniDSP but holding off on hooking that up until I'm more comfortable with what I'm doing now.
Update:
I tried 45Hz and 55Hz for main sub crossovers. It actually made things worse, so back to 50Hz.
post #6 of 11 Old 01-23-15, 09:19 AM Thread Starter
finalrinse's Avatar
Finalrinse
I've added a MiniDSP and EQ filters. Still playing around but this is first attempt.
Green is Audyssey and Red is Audyssey with MiniDSP and EQ filters. What do you think?
post #7 of 11 Old 01-23-15, 07:32 PM
willis7469's Avatar
I'd say looks like a nice house curve! I bet it sounds great.
willis7469 is online now
post #8 of 11 Old 01-23-15, 09:37 PM Thread Starter
finalrinse's Avatar
Finalrinse
willis7469 wrote: View Post
Thanks! Yes, I've really been enjoying it! I decided to stop fiddling with it for now and just sit back and watch/listen to movies and concerts.
post #9 of 11 Old 01-23-15, 09:51 PM
willis7469's Avatar
That can be hard to do once the tweaking begins. lol. Good choice though. Let it all sink in and really evaluate. Most of all, enjoy!
post #10 of 11 Old 01-24-15, 12:15 PM
AudiocRaver's Avatar
Wayne Myers
Your work and the result are to be applauded. Bet it sounds great. HOWEVER... addressing your earlier post (for future reference):
Those dips are narrow enough that, in real-life listening terms, even a sub expert would probably never hear them, as you pointed out in your next sentence...
Precisely, and it happens to some degree in every listening room.
Pretty impossible.
Any result can be improved upon. How do you know when to stop, when to continue??
  • If you are enjoying the fiddling, keep going.
  • If you just want it to sound great, remember that
    • Narrow dips are inaudible under normal listening conditions.
    • Narrow dips are inaudible under normal listening conditions. Repeated for emphasis.
    • Most fiddlers - self included - tend to EQ well beyond the point where it helps the music or movie sound better.
    • More EQing usually gives a result that applies to a narrower listening area (not necessarily a problem) and makes other areas in the room sound worse (also not necessarily a problem).
Again, you did fine work. Just taking the opportunity to make a couple of points about EQing in general.
AudiocRaver is offline
rew , sweeps
