REW DBFS - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
REW DBFS
Discuss REW DBFS in the Subwoofer Equalization | Calibration forum; REW DBFS Just wondering how accurate the DBFS output level is in REW. For example I have calibrated my system using AVIA ...
Old 04-25-08, 05:02 PM   #1 (Link)
Alias: fireanimal
User: #5003
Since: Dec 2006
fireanimal is offline
REW DBFS
Just wondering how accurate the DBFS output level is in REW. For example I have calibrated my system using AVIA on my HTPC with PowerDVD, to be at reference level 85db. When I use REW I set the output level at -20 DBFS, but the signal is 6db hotter then the calibration, and that is with only one speaker playing. So I have to lower the output to -26dbfs for 80db.
Just wondering if anyone has seen this before. I am using Vista and all volume sliders are at max.
Thanks
Old 04-26-08, 06:46 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: REW DBFS
The dBFS setting on REW is exact, but what it means in output levels depends on what other gains and scalings are applied to the audio data on the way to your final output. What levels are the test signals on PowerDVD?
Old 04-26-08, 06:48 AM   #3 (Link)
Alias: fireanimal
User: #5003
Since: Dec 2006
Re: REW DBFS
The volume sliders and gains are set at the same level. I have tested with Powerdvd 7.0 and Powerdvd 8.0.
Maybe there is something going on with powerdvd?
I was using Avia through powerdvd which is -20dbfs.
Similar Threads
AVIA & DVE actual dBFS levels MACCA350 General Discussion 1 06-19-07 04:27 AM
"Highest level in the measurement is -49 dBFS" need help with REW union1411 REW Forum 5 05-12-06 04:55 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
