Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss Manual Inputs Using REW in the Equalization | Calibration forum; Manual Inputs Using REW Hello All, I am just getting started with REW. I do not currently have a laptop and I am not ...
Views: 594 - Replies: 17
Old 04-26-08, 01:21 PM   #1
Alias: eye1
User: #20027
Since: Apr 2008
  eye1 is offline
Hello All,
I am just getting started with REW. I do not currently have a laptop and I am not quite ready to move my pc into my HT room.
Could any one help with making basic SPL readings and manually entering in to REW to get a room analysis? I hesitate to ask but I have not found info in these forums here.
I have a Pioneer VSX-92TXH and a HSU BAS test disc if this helps.
Thanks for your input.
Old 04-26-08, 02:56 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Manual Inputs Using REW
Go to the downloads page and get the Excel .xls file that corresponds to your Radio Shack meter type. The calibration for your meter is built in.
Then download the 1/6th octave sinewaves and make a CD.
That's about all you need.
Old 04-26-08, 03:53 PM   #3
Alias: eye1
User: #20027
Since: Apr 2008
  eye1 is offline
OK Thanks,
I have done that now and to get the readings I need to do the following correct?
1. Establish the 75dBL reference level by playing the CD or using the tones if available in my AVR?
2. Play the CD and mark down the level from the SPL Meter
3. Enter into the Excel sheet.
Should I disconnect my front mains?
Do I want to run my AVR in signal direct mode with no processing?
Old 04-26-08, 04:19 PM   #4
Alias: brucek
User: #6
  brucek is offline
Yeah, it's best to disconnect the mains and do a sub only measure. This way you have no other influences. Simply remove the speaker wires for the mains (with power off).
Normally you set the receiver in the standard digital stereo mode with the subwoofer crossover set as you would normally (i.e. 80Hz).
Also note that you may have some peaks and so if you set the 75dB at some huge peak, the graph will show a bit low. So play the CD up through the 1/6th octave tones first and get a feel for it. Then maybe pick an appropriate frequency (50Hz) that doesn't seem ridiculously louder than the rest and set your 75dB level on the receiver volume at the listening position, and then you're ready to go......
Old 04-26-08, 06:35 PM   #5
Alias: eye1
User: #20027
Since: Apr 2008
  eye1 is offline
Thank you for your help Bruce,
I currently run my X-Over at 50 so I did a graph with this X-Over and another at the 80Hz X-Over.
My mains go down to 30-35hz so I set my crossover about double this at 50hz.
This 1st JPG graph is with the 50hz X- Over
The 2nd JPG graph is with the 80Hz X-Over
Do you have any thoughts on what you are seeing with these?
I start out well out of the gate with good readings at the first octaves but at the 22 there is a significant drop. Will the equalizer in my Pioneer VSX-92 be able to lift up this drop?
I am going to purchase the USB Sound Card so I can go deeper into this but I thought this would be a great place to start to learn about calibrations.
Thanks for your help and thoughts.
Old 04-26-08, 06:56 PM   #6
Alias: brucek
User: #6
  brucek is offline
I have a couple observations.
I guess you can see what I was talking about with respect to the level you set the receiver to take the test. It's a bit high.
I'm surprised about the low end extension you're showing. You seriously had that type of output down to 7Hz?
You do indeed have a null at 22Hz and a peak at about 25Hz. This is where REW would offer more accuracy. I doubt the equalizer can do much to a true null, but it can bring down a peak easily.
Big recommendation...... use REW - so much easier..
Old 04-26-08, 07:55 PM   #7
Alias: eye1
User: #20027
Since: Apr 2008
  eye1 is offline
I thought the out put was close to 80. Hmmm
The HSU VTF-MK3 is known for great low end extension. These are the readings read on the SL Meter. I thought it was odd also that I would immediately begin to show high readings. From all my reading on the forums I usually see the first octaves show very low on the graphs.
What X-Over do you recommend after looking at these graphs?
Are these readings close to what you would like to see in a perfect world?
I am one step away from being REW ready - I was at Micro center today and the only external USB they had was the Sound Blaster for 50.00 From what I have read some people are having success using this one with Vista. I would like the Turtle Beach brand but I am trying to find it for a good price.
Thanks
Old 04-26-08, 08:08 PM   #8
Alias: brucek
User: #6
  brucek is offline
It's impossible to recommend a crossover until you see the mains only graph.
I can't resolve how your sub has continuous rising output level down to 7Hz. The specification on the HSU VTF-MK3 using the max extension mode is 18Hz +/-2 dB. I'd like to see an REW response plot. Are you using a Radio Shack meter with the C-mode switch position? (and using the correct excel plot?
Old 04-26-08, 08:18 PM   #9
Alias: eye1
User: #20027
Since: Apr 2008
  eye1 is offline
Yes, C weighting - Slow Response at the 80
I entered in the readings after subtracting from 80 starting from the first sounds.
Old 04-26-08, 09:10 PM   #10
Alias: brucek
User: #6
  brucek is offline
Can you explain what this means?
Bookmark and Share
Dish Network
