Can't calibrate my soundcards - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Can't calibrate my soundcards in the Subwoofer Equalization | Calibration forum; Can't calibrate my soundcards Hello from a newbie, I've downloaded the REW and installed the Java update. I have two cards, a Delta 1010 ...
Old 05-25-08, 12:39 AM   #1 (Link)
New Member
Alias: Jet
Loc: Hong Kong
User: #21136
Since: May 2008
pearldivers is offline
I have two cards, a Delta 1010 and an Echo MiaMIDI, neither of which I can calibrate.
I've tried looping Left to Left, then Right to Right on both cards, ensured monitoring is off and adjusted levels so that out is same as in.
I have triple-checked my computer for default in/out of the audio for each test on each card.
However, no matter what settings I use on the cards, from minimum fader to maximum fader levels or anything in between, the "measure" dialogue box always tells me the reading is -71dB and that I need to readjust the cards. The graphs of the responses that are generated are just a few blocked lines on the right end, not a response curve.
So...after half a day of failure, I'm stuck and have no idea what to do next.
Any tips?
Oh, my computer is a Mac G4.
Jet
Old 05-25-08, 08:03 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Can't calibrate my soundcards
pearldivers, I moved your post to the REW forum, as it's more suited here.
Can you tell us what operating system version you're using?
Old 05-25-08, 10:22 AM   #3 (Link)
New Member
Alias: Jet
Loc: Hong Kong
User: #21136
Since: May 2008
I'm running OSX Tiger 10.4
Jet
Old 05-25-08, 06:01 PM   #4 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
In 10.4 Java applications can only access the built-in audio inputs, regardless of what is set as the default input. In 10.5 inputs from USB soundcards can be selected, though it looks like Firewire cards cannot.
Old 05-26-08, 12:18 AM   #5 (Link)
New Member
Alias: Jet
Loc: Hong Kong
User: #21136
Since: May 2008
John,
thanks for the info.
Cheers,
Jet
Old 05-26-08, 01:55 AM   #6 (Link)
Alias: David
Loc: Los Angeles, Ca
User: #20731
Since: May 2008
htguy is offline
One of my prior posts was a little confusing on this issue. On 10.5, a firewire card can be selected as an output device. The name of the card in my case appears in the drop down list. On 10.4, it seems like the card can also be selected as an output device, but in my case the name was blank on the drop down list.
Old 05-26-08, 05:09 PM   #7 (Link)
New Member
Alias: Civil
User: #20845
Since: May 2008
playitbyearmusic is offline
So, if in 10.4 only the inputs from the built in can be accessed, is there anyway to calibrate the MOTU 828 MK1? I have MAC G4 also and I was having the same problem.
PlayItByEar MUSIC.
Old 05-26-08, 05:36 PM   #8 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
You could calibrate a loop from the MOTU output to the built-in input.
Old 05-27-08, 12:11 AM   #9 (Link)
New Member
Alias: Jet
Loc: Hong Kong
User: #21136
Since: May 2008
John,
so, in fact, the software is unuseable on any Mac under 10.5....is that correct? I'm asking because it would be a nice "advisory" to post up at the download point, as it says "tested on 10.4" on the page.
Whilst the software allows me to "select" the inbuilt audio, I can't establish the necessary loop.
Cheers,
Jet
Old 05-27-08, 04:08 AM   #10 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
No, that's not correct, I had it working without problems on an Intel Mac Mini under 10.4 using the built-in audio, with the built-in devices set as the defaults under the Mac's sound preferences and REW set to use the default devices. Only needed 10.5 to access USB soundcard inputs.
Old 05-27-08, 09:17 AM   #11 (Link)
New Member
Alias: Civil
User: #20845
Since: May 2008
Thanks for the response! Is that the only connection that I would have to make to calibrate the MOTU 828? Would it be better to use the main outs or Analog 1 - 2 outs? Should I connect the left or right output from the MOTU to the built in input? Also, I would have to connect the SPL meter to an "in" on the MOTU and then connect an out from the MOTU to the built in input on the MAC, right?
Old 05-27-08, 10:14 AM   #12 (Link)
New Member
Alias: Jet
Loc: Hong Kong
User: #21136
Since: May 2008
John,
I've tried using the in-built audio and ensured "default device" shows in the dialogue box, but the measure yields
-54dB and I'm prompted to do a card adjustment...same as when I try to measure my Delta 1010 and the Echo card, only they yield an ever lower dB.
I guess I'm just unlucky, REW simply won't run on my Mac.
Thanks anyway for your advice, appreciated!
Jet
Old 05-27-08, 11:33 AM   #13 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Jet, did you set built-in audio as the default for playback and recording in the Mac's sound preferences? (before starting REW).
Old 05-27-08, 10:14 PM   #14 (Link)
New Member
Alias: Civil
User: #20845
Since: May 2008
Okay room, I'm back!! Mac 733MHz doesn't support nor have an built in input. It only supports built in output. Now what do I do to calibrate the MOTU 828 MK1?
Plaese help!!
Old 05-27-08, 10:42 PM   #15 (Link)
New Member
Alias: Jet
Loc: Hong Kong
User: #21136
Since: May 2008
Yes, I did. I double-checked the Audio-MIDI selection in Utilities as well, and both it and the sound preferences from the Apple menu were ticked for "in-built audio/line in".
Jet
Old 05-28-08, 04:33 AM   #16 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
playitbyearmusic wrote: View Post
You can't. I suggest you try FuzzMeasure, there is a 10.4 version still available though the developer has moved on to 10.5 for the current version.
Similar Threads
Calibrate anyway? Bjarbor SPL Meters | Mic's | Calibration 5 01-11-08 08:10 AM
How to calibrate to reference level supervsl General Discussion 7 12-28-07 10:16 AM
Soundcards Tobester BFD Forum 2 10-17-07 07:10 PM
Need to calibrate RS SPL for rew? duxfan REW Forum 3 10-16-07 10:10 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
