Which Midi to USB connection to use? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Which Midi to USB connection to use? in the Subwoofer Equalization | Calibration forum; Which Midi to USB connection to use? Do I HAVE to use one of the midi to usb cables listed in the comm panel, or can I ...
Old 06-03-08, 05:14 PM   #1 (Link)
New Member
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
RobertR is offline
Do I HAVE to use one of the midi to usb cables listed in the comm panel, or can I use another, more generic such adaptor and simply tell REW I'm using, say, the Creative device?
Old 06-03-08, 07:13 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Which Midi to USB connection to use?
The cable most commonly used is the Edirol UM-1EXEdirol UM-1EX . This connects from the PC's USB port to the BFD's Midi input. Has nothing to do with the soundcard.
The only purpose of this connection is to pass filters from REW to a BFD through a cable. You can enter them quite easily by hand if you don't want to buy any cable.
You should read this and this
Old 06-04-08, 03:43 PM   #3 (Link)
New Member
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
RobertR is offline
Do I HAVE to use the Edirol, or can I use something else? I ask because the comm panel gives certain choices by name.
Old 06-04-08, 03:49 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
No, what do you have in mind?
Old 06-04-08, 03:56 PM   #5 (Link)
New Member
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
RobertR is offline
I found an inexpensive midi to usb cable on Ebay.
Old 06-04-08, 05:02 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Great, use that............
Old 06-04-08, 05:10 PM   #7 (Link)
New Member
Alias: RobertR
Loc: Riverside, CA
User: #5951
Since: Jan 2007
RobertR is offline
Thanks Bruce
Similar Threads
why not use the USB soundblaster digital out connection? penngray REW Forum 2 05-30-08 06:55 PM
USB/MIDI interface -XP Media center What works bobmills REW Forum 4 05-18-07 10:09 AM
REW not recognising USB Midi cable gmoorc REW Forum 10 05-02-07 05:34 PM
USB to MIDI interface... aceinc REW Forum 3 03-03-07 08:59 PM
DIY Midi to USB cable GaryK BFD Forum 6 04-21-06 02:47 PM
Mach 5 Audio
