REW windowing markers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss REW windowing markers in the Subwoofer Equalization | Calibration forum; REW windowing markers John, Is there are way in REW to change the default window markers of -125ms and 500ms? Ideally you would ...
Old 05-05-08, 05:15 PM   #1 (Link)
New Member
Alias: Jack Hidley
Loc: Danville, CA
User: #15363
Since: Jan 2008
Jack Hidley is offline
John,
Is there are way in REW to change the default window markers of -125ms and 500ms? Ideally you would be able to set these in the ini file to whatever value you needed. And once you change them in use, REW would remember the new values for consecutivie measurements during that session. It would only start using the ini values again once REW was closed and opened.
Thanks,
Jack Hidley
Old 05-06-08, 05:44 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: REW windowing markers
Not at the moment, I'll add that to the features list for the next release.
Old 05-06-08, 12:58 PM   #3 (Link)
New Member
Alias: Jack Hidley
Loc: Danville, CA
User: #15363
Since: Jan 2008
John,
Thanks.
Jack Hidley
Mach 5 Audio
