REW Forum
first graph questions
Discuss first graph questions in the Equalization | Calibration forum; first graph questions How is everyone. This is my first post and I would like to thank everyone for taking the time to ...
Views: 403 - Replies: 14
Old 05-12-08, 12:24 PM   #1
Alias: chris
User: #20558
Since: May 2008
  hot grits is offline
How is everyone. This is my first post and I would like to thank everyone for taking the time to help us all out.
I made my first graph of my sub eD A5-350 and im a little surprised at how steep it drops off at 30 hz. I was expecting a much better response between 20 and 30 hz. I have attached my graph. Could this be because of the frequency response of my soundcard, sub placement or am I doing something wrong?
Old 05-12-08, 12:35 PM   #2
Alias: chris
User: #20558
Since: May 2008
Re: first graph questions
That graph is without audessey EQ on my receiver. This graph is with audessy enabled. It is still dropping off sooner than I expected. Do you think my main problem is sub placement?
Old 05-12-08, 12:56 PM   #3
Alias: brucek
User: #6
  brucek is offline
Hopefully, you've gone through the calibration routine of the soundcard and taken a measure of a straight looped back cable from line-out to line-in, that should have resulted in a perfectly flat response. If you've done that, you know the soundcard is not at fault.
Yeah, sub placement is very important. Is it in a corner?
Old 05-12-08, 01:04 PM   #4
Alias: chris
User: #20558
Since: May 2008
brucek wrote: View Post
Yes i have done the soundcard cal and it is perfectly straight. The sub is in a rear corner behind the couch. I am going to try 2 other spots. I expected this sub to drop off at around 20hz not 30 hz. Thanks for any input, brucek
Old 05-12-08, 01:04 PM   #5
Alias: chris
User: #20558
Since: May 2008
The black solid line is my mic, correct? Does this look right?
Old 05-12-08, 02:43 PM   #6
Alias: brucek
User: #6
  brucek is offline
Sure, as long as the file you downloaded matched the meter you have, then it's correct.
Old 05-12-08, 02:44 PM   #7
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
hot grits wrote: View Post
Take a look at the legend behind the graph. What does it say?
I could tell you the answer but it's better if understand the different curves for soundcard and mic...
Klipsch (THX2) | Crown | SVS | SlimDevices | Sony | Pioneer | Yamaha
Old 05-12-08, 03:14 PM   #8
Alias: chris
User: #20558
Since: May 2008
yes it is the mic. Moving my sub helped the low end extension a bit. It really is amazing how moving the mic to different seating positions affects things. What do you guys mainly do, find the best spot for the sub when sitting in the main sitting position and let the chips fall where they may for the rest of seating area?
Old 05-12-08, 03:19 PM   #9
Alias: brucek
User: #6
  brucek is offline
Well, most of us equalize with a BFD. This allows you to create one program for a perfect (selfish) sweet spot, and another that is the average over a wider area, so that everyone gets a decent response. You can also create programs for music and HT.
But you're correct, the response at one seating position is very different from another....
Old 05-12-08, 03:29 PM   #10
Alias: chris
User: #20558
Since: May 2008
Thanks, you guys are a big help. I plan on getting BFD sometime soon. Right now I am just trying to find the best spot for my sub. I will post some graphs of my results at different positions.
Old 05-12-08, 05:01 PM   #11
Alias: chris
User: #20558
Since: May 2008
ok, I tried a couple different spots for my sub. I made a few graphs at 3 different listening positions.
Main listening spot
Location A / Location B
Old 05-12-08, 05:02 PM   #12
Alias: chris
User: #20558
Since: May 2008
Next listening spot
Location A
Old 05-12-08, 05:05 PM   #13
Alias: chris
User: #20558
Since: May 2008
Location B
Old 05-12-08, 05:09 PM   #14
Alias: chris
User: #20558
Since: May 2008
Disregard the above posts. I had a little trouble uploading the pics. I will make a new thread to ask my question.
Sorry for the confusion.
Old 05-13-08, 01:34 AM   #15
Alias: Jerome
jerome's Avatar
Loc: Norway
User: #8468
Since: Apr 2007
  jerome is offline
You can just delete/edit your posts to correct your mistakes. By editing the first post, you can also change the thread name (if you wish to).
When it comes to sub placement, take a look at this one for instance:
http://www.hometheatershack.com/foru...ood-sound.html
