REW ForumDiscuss Spl correction files. in the Equalization | Calibration forum; Spl correction files. Quick question. I must be doing something wrong. I loaded the correction files for my RS meter. I graphed my ... |
Views: 386 - Replies: 2
| Spl correction files. Quick question. I must be doing something wrong. I loaded the correction files for my RS meter. I graphed my sub w/ the files loaded, w/o the files loaded, c weighting checked and not checked and every possible combination. The graph is exactly the same no matter what I do. I assume I should be seeing a difference. What could I be doing wrong? | ||||
| | #2 | ||||
| Re: Spl correction files. If you load/unload a calibration file or select/deselect C weighting compensation and want to see the effect on an existing measurement you need to re-apply the Impulse Response windows to recalculate the response. Click the IR windows button (top right) then click the Apply Windows button. Note that C-weighting compensation, when selected, is only applied outside the range covered by the calibration file. | ||||
