Help with REW, RCA to XLR connection question. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Help with REW, RCA to XLR connection question. in the Subwoofer Equalization | Calibration forum; Help with REW, RCA to XLR connection question. I have the following equipment so far Nady cm-100 micro power phantom power supply (+48V for the nady) USB sound ...
Old 05-14-08, 01:58 PM   #1 (Link)
Alias: Penngray
Loc: FL
User: #6840
penngray is offline
Nady cm-100
USB sound blaster card
Notebook
REW software loaded.
Can I just connect my USB sound card to the phantom power supply using just a RCA to XLR cable?
Thanks!
Old 05-14-08, 06:25 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Help with REW, RCA to XLR connection question.
No, you require a microphone preamp. The MicroPower is simply a phantom power supply. You require a preamp to bring the low level of the microphone up to line level before you feed the soundcard.
Old 05-14-08, 06:46 PM   #3 (Link)
Alias: Penngray
Loc: FL
User: #6840
penngray is offline
Thanks...always more money
I should have bought the Galaxy mic instead...live and learn.
Similar Threads
BFD RCA to TRS vs XLR input levels different floydo BFD Forum 2 05-13-08 07:35 AM
Where to buy balanced XLR to RCA cable? Trekari Remotes | Cables | Accessories 14 02-22-08 01:25 AM
Connection question ondee57 General Discussion 2 07-21-07 08:03 AM
XLR or 1/4" to RCA Cables Peter De Smidt BFD Forum 7 01-02-07 02:27 PM
My Custom DIY XLR to RCA cables Owen Bartley BFD Forum 13 10-27-06 08:52 AM
Mach 5 Audio
