REW Forum
rme 9636, calibration issue
Discuss rme 9636, calibration issue in the Equalization | Calibration forum; rme 9636, calibration issue Hello I`m trying to calibrate my soundcard and get a very monotone signal similar to the one described in the ...
Views: 511 - Replies: 16
Old 05-17-08, 10:37 AM   #1
nouon
Inactive
Alias:
User: #
Posts: n/a
Hello
I`m trying to calibrate my soundcard and get a very monotone signal similar to the one described in the help text as an issue with loopback
There is an option to turn on/off direct montoring in the rme panel but it doesn`t seem to make any difference
any ideas?
Thanks
Old 05-17-08, 10:44 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: rme 9636, calibration issue
You should have no signal when calibrating the soundcard, since the only connection to and from the soundcard during this procedure is the loopback cable.
The monitor will mute and unmute the line-in in the Windows Playback Mixer. Does it?
Old 05-17-08, 11:01 AM   #3
nouon
Inactive
Alias:
User: #
Posts: n/a
sorry that would be the end signal response is very monotone, I`m not having any signal when testing
I cannot see any mute button for the line in in the windows mixer, there is just a description of which lines are being used in and out
under the "device module" there is a mute button, but it doesn`t change when I turn on/off direct monitoring in the rme settings
Old 05-17-08, 11:31 AM   #4
Alias: brucek
User: #6
So, you're using VISTA?
Old 05-17-08, 11:37 AM   #5
nouon
Inactive
Alias:
User: #
Posts: n/a
no, I use xp
the mixer should be in the control panel under sounds and audio devices right?
Old 05-17-08, 11:42 AM   #6
nouon
Inactive
Alias:
User: #
Posts: n/a
I managed to open the mixer, but there is only one "table" showing analog 1+2 (I assume analoge out) with a "mute all" button
Old 05-17-08, 12:04 PM   #7
Alias: brucek
User: #6
Double click the little speaker icon in your system tray.
It will show the Playback Mixer as shown below.
The device selections are selected with the Options pull-down and select Properties.
To select Record mixer, simply click Recording. See below.
You want line-in muted in Playback and selected in Recording.
Windows XP Playback mixer device select
Name:  Windows XP Playback Mixer 1.jpg
Windows XP Record mixer device select
Name:  Windows XP Record Mixer 1.jpg
Old 05-17-08, 12:16 PM   #8
nouon
Inactive
Alias:
User: #
Posts: n/a
Hello, thanks the thorough reply
the problem is that under options, playback and recording is greyed out and the only button which functions says "other" and "analog 1+2"
Old 05-17-08, 12:52 PM   #9
Alias: brucek
User: #6
Then your card has taken over Windows.
I can only think to go to the control panel and look for the cards own application and see if you can control it from there.
If not.... you're toast. You'll have to get a different card perhaps. Your best bet is a simple cheap analog stereo soundcard. REW only uses simple analog line-in and line-out. No digital.
Old 05-17-08, 12:55 PM   #10
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
Can you post a screenshot of the calibration result? And perhaps a shot of the RME control panel. You should have an option to turn off monitoring somewhere in the RME panel.
Old 05-17-08, 01:19 PM   #11
nouon
Inactive
Alias:
User: #
Posts: n/a
Hello
I couldn`t capture the pop upmenu from the rme mixer, but it says under options "asio direct monitoring"
thanks
Old 05-17-08, 01:21 PM   #12
nouon
Inactive
Alias:
User: #
Posts: n/a
the card has both analog and digital in/out, of course I use the analog for the calibration
Old 05-17-08, 01:28 PM   #13
Alias: brucek
User: #6
To capture a popup, you press PrtScr (print screen) button on your keybaord and then paste the result to Paint or some graphic program. To capture the active screen you can also use Alt + PrtScr.
Old 05-17-08, 07:48 PM   #14
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
Where it shows "Monitor Main" click to turn off the indicator next to A1+2. Should be OK then.
Old 05-18-08, 08:51 AM   #15
nouon
Inactive
Alias:
User: #
Posts: n/a
The monitor main button is turned on and cannot be turned off, I can activate the dim button belove it, but all I get then is to much headroom (not any signal)
maybe I`ll just have to bite the bullet and buy a cheap second hand m-audio or something
Old 05-18-08, 05:01 PM   #16
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
I wouldn't give up just yet. You may be able to change the monitoring to A3+4 for example, but there should be a way to set the card up to do what is required. Do RME have a support forum or a support email address? Worth a shot.
Old 05-19-08, 09:35 PM   #17
nouon
Inactive
Alias:
User: #
Posts: n/a
Thank you
and thank you for creating this program for free,
I´ll try your suggestions and work some more with it when I get some spare time
