REW Forum
GWC AA1500 USB Sound Card
Discuss GWC AA1500 USB Sound Card in the Equalization | Calibration forum; GWC AA1500 USB Sound Card Folks, This is my first post. Thanks to everyone for a great forum. I've read through most everything concerning BFD ...
Views: 728 - Replies: 9
Old 05-18-08, 07:36 AM   #1
deadhead
Inactive
Alias:
User: #
Posts: n/a
Folks,
I've read through most everything concerning BFD and REW. My 1124 should be here soon. I don't have an SPL yet, but I'm working on it. I think I have all the necessary cables, splitters, connectors to use REW. I still need a sound card with a line in, however.
Has anyone tried this item as an external sound card for their laptop?
http://www.newegg.com/Product/Produc...82E16829126101
My HSU VTF-2 Mk 3 can only go in the front left corner of the room, pretty much right where it is now +/- an inch or two. I want to do this right, BUT, I'll probably only do it once. Soooooooo, although I dropped some coin on the sub, I don't want to buy the CM-140, or a mic and mic amp, or an $80 sound card. I know I can spend time on eBay, waiting for a used SoundBlaster 24bit, but well, I'm also impatient.
Any advice would be greatly appreciated. A quick glance by someone knowledgeable with a "Should work, give it a shot" or "Won't work because..." reply would be awesome.
Thanks much,
deadhead
Old 05-18-08, 09:40 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: GWC AA1500 USB Sound Card
Yeah, seems to have everything you'll need. It's a low USB spec, but should be fine.......
Old 05-18-08, 10:54 AM   #3
deadhead
Inactive
Alias:
User: #
Posts: n/a
brucek,
Thanks much for your work here, and the quick reply.
Should I use the the Front Audio Output and not the Center/Subwoofer Out?
deadhead
Old 05-18-08, 11:53 AM   #4
Alias: brucek
User: #6
Yeah, the Front will be the line-out stereo (the mode to use) and then use the line-in as marked. Remember those are stereo jacks, so you require stereo plugs...... See here...
Old 05-18-08, 12:27 PM   #5
deadhead
Inactive
Alias:
User: #
Posts: n/a
Roger that. I have two mini-to-phono stereo splitters, and about 3000 feet of rca cable, or at least it seems like it. I think I've saved every cable from every TV, receiver, radio, microwave I've ever owned...
Old 06-11-08, 09:36 AM   #6
deadhead
Inactive
Alias:
User: #
Posts: n/a
Folks,
Just wanted to let everyone know this USB sound thingy seems to work just fine. Not bad for the money.
deadhead
Old 06-11-08, 12:12 PM   #7
Alias: Intelonetwo
Loc: Sacramento, Ca
User: #6751
  HionHiFi is offline
Sweet, thanks. Seems like a good deal on a sound card that will work with REW. Was the shipping charge workable?
Old 06-11-08, 12:30 PM   #8
deadhead
Inactive
Alias:
User: #
Posts: n/a
Newegg is the best. Shipping is always reasonable, but always better if you get multiple items. I didn't mind whatever the charge was. It beat trying to win a Sound Blaster on eBay.
deadhead
Old 06-11-08, 12:34 PM   #9
deadhead
Inactive
Alias:
User: #
Posts: n/a
By the way, read the thread called "Thick person about to cry" in this forum and set the soundcard up as directed. That will save you hours.
deadhead
Old 06-11-08, 12:46 PM   #10
Alias: Intelonetwo
Loc: Sacramento, Ca
User: #6751
  HionHiFi is offline
I don't think I've ordered anything from newegg, although I've seen many products they sell.
Thanks for the soundcard advice, I'll pass it along, as I already have a sound card.
