First attempt at REW - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss First attempt at REW in the Subwoofer Equalization | Calibration forum; First attempt at REW I've finally had time to run REW and check out how my SVS 20-39 plus is performing in my room. ...
Old 06-03-08, 10:24 AM   #1 (Link)
Alias: jmacd27
Loc: Florida
User: #14418
Since: Dec 2007
jmacd27 is offline
I've finally had time to run REW and check out how my SVS 20-39 plus is performing in my room. The room is about 2700 cu ft "L" shape and opens to a kitchen and hallway.
The sub is in a corner and I really can't move it due to keeping the wife happy.
I wanted to ask the very helpful members in here for their opinions and suggestions.
Samsung FP-T5884 58" plasma, Denon 3808CI receiver, Samsung BDP1400 Blu Ray player,Sony PS3
Infinity Beta 50 mains, Infinity Beta 360 center, Polk Audio Monitor 30 surrounds, SVS 20-39PC-Plus subwoofer
Brighthouse HD DVR, Logitech 880 Remote
Old 06-03-08, 12:36 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: First attempt at REW
You have a wide peak between ~35-60Hz, but it isn't that bad. I might take some measures around the listening area to see how that peak responds to positional changes in the seating. If you can't move the sub or the listening position there's always EQ, but I would hesitate on that, given your rather good response without...
Add the mains and take another measure and see how the crossover looks.
Old 06-03-08, 03:58 PM   #3 (Link)
Alias: jmacd27
Loc: Florida
User: #14418
Since: Dec 2007
jmacd27 is offline
Thanks for the reply Bruncek. I just had time to quickly try and lower the wide peak ~35-60Hz with the built in filter on the SVS sub. I could probably get it a little flatter with a bit more time tweaking.
I'll try take some readings with the mains later on tonight, the family came home so I had to pack up the testing this afternoon.
I was wondering what your opinion is on the remaining peak at 84 and 98Hz. Are those two peaks large enough to worry about. They don't look to bad once I select 1/3 octave filtering.
I am probably going to try and use a house curve, as I find the bass a little lacking to my tastes with the current setup. Do I need a BFD or could I get away with just boosting the sub level?
Thanks again for your time.
Old 06-03-08, 07:05 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
They aren't a concern until you add the mains and see what happens. Any after the crossover is pretty much ignored until you run the two together. Often the phase adjust will clear any crossover problems once the mains are added.
Yeah, you may get away with just boosting the sub a bit once you see how it looks with the mains. It's really quite a good response. It would be a shame to stick a digital device in that line.
Old 06-04-08, 12:51 PM   #5 (Link)
Alias: jmacd27
Loc: Florida
User: #14418
Since: Dec 2007
jmacd27 is offline
I got a chance today run some more sweeps. The results are as follows.
These first two below are on the sub only with just the AVS internal filter smoothing the 35- 50hz rise.
The first graph is the raw result.
And this graph is with 1\3 octave filter applied
This graph is with the mains running and a room curve applied as well.
And the same with 1/3 octave smoothing
And finally a full range sweep with 1/3 octave filter applied.
I'll still do some tweaking and fine tuning and see if I can smooth out the mains a bit, but i'm happy with the results over all, the sub has good response to 13hz. I haven't bothered to try blocking one of the ports on the sub to raise the bottom end, it seems fine to me how it is now with the room gain. I might give it a try some day when I have some free time.
I haven't had a chance to demo much listening material out yet, but what i have listenend to sounds very nice. There is no boom and the bass is nice and tight.
I'll try and watch a Blu Ray tonight and give the set up a good work out.
Thanks again brucek for your valued input.
Old 06-04-08, 01:27 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, looks quite good. I suspect you're using a Radio Shack meter for measuring, since you have the standard ~5KHz peak........ Normally we recommend stopping at ~3KHz with an RS meter......
Old 06-04-08, 01:47 PM   #7 (Link)
Alias: jmacd27
Loc: Florida
User: #14418
Since: Dec 2007
jmacd27 is offline
Yes I am using the radio shack meter. I'm a little surprised at the peaks and valleys in the mains. I figured audessy would flatten them out better. Either way they still sound pretty good so far.
Old 06-04-08, 09:38 PM   #8 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
jmacd27 wrote: View Post
Nice response
Do you have any accoustical treatment installed??? ... just curious
Old 06-05-08, 07:14 AM   #9 (Link)
Alias: jmacd27
Loc: Florida
User: #14418
Since: Dec 2007
jmacd27 is offline
I don't have any room treatments in place. I was actually expecting to have a much worse room response.
I did mess around a little more last night. I did find with some music/movies the bass seemed a bit boomy at times. I tried setting my crossover to 60 hz from 80hz and the the results have improved. I will try to take some measurements and post up the graphs.
Similar Threads
First Time here and 1st attempt at using REW rafaelsmith REW Forum 4 03-12-08 08:35 AM
1st attempt at REW cburbs REW Forum 40 02-06-08 05:22 PM
First REW graph attempt - HSU3.3 camtah REW Forum 11 03-03-07 11:28 PM
First attempt at REW - Could use some quick feedback (no pun intended) jaegertc REW Forum 18 02-26-07 09:00 AM
First attempt with REW, how am I doing? Darren REW Forum 19 06-16-06 03:55 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
