REW Forum
Trouble getting started...
Discuss Trouble getting started... in the Equalization | Calibration forum; Trouble getting started... Here are my settings that you addressed: I tried it this way at both 44.1 and 48 kHz...still no output....
Views: 1698 - Replies: 66
Old 06-25-08, 09:19 PM   #51
tickertape
Inactive
Alias:
User: #
Posts: n/a
Re: Trouble getting started...
Old 06-26-08, 12:53 PM   #52
tickertape
Inactive
Alias:
User: #
Posts: n/a
Any more thoughts ?
...maybe I should just go back to my noisy XP machine ? At least REW was working there.
Old 06-26-08, 01:35 PM   #53
Alias: brucek
User: #6
  brucek is offline
Any more thoughts ?
Yeah, lots of thoughts about your problem, but every one I come up with, I argue myself out of it. This really is a head scratcher. I just don't get it.
There's a couple obscure things that have crossed my mind, but I can't really support the arguments.
The first is to take a look at the device manager again and look under the USB controllers and be sure you see USB Composite Device showing for where you have the soundcard plugged in and that the driver is happy.
Below you see I have two USB Composite Devices plugged into my four USB ports of the laptop. One is for a mouse and one is for my SRM soundcard.
They both show USB Composite Device and are good to go.
Name:  Vista USB usage.JPG
The next thought is my confusion why you show REW in the Vista Volume Mixer picture you posted, instead of JAVA platform SE bin.... as John suggested it would, and indeed mine does when REW is run (as shown below).
Is your Java up to date?
Name:  Vista Main Volume Mixer.JPG
I also wondered why you don't have SPDIF set to None or OFF in this picture below.
My card has the same sort of selection and I have to set it to OFF to get the analog to work....
Anyway, those are the only ideas I have come up with...
EDIT: I think my last 2 points are connected and deserve some investigation....
I just looked at the Vista Volume Mixer again on my laptop (since I normally use digital SPDIF out of the soundcard) and not analog, because I use the laptop for my streaming music connection to my processor. The Vista Volume Mixer jpg I show above (where it shows JAVA platform SE bin..when you run REW) is when I have digital set to OFF and analog connected for REW.
But look at the Vista Volume Mixer picture below when I have my soundcard set to SPDIF ON. It looks just like yours does....... possibility that may be the fault.. turn off digital SPDIF output.
Name:  Vista Volume Mixer with digital.JPG
Old 06-26-08, 05:20 PM   #54
tickertape
Inactive
Alias:
User: #
Posts: n/a
On Device Manager, I see a Tascam USB device, but not a "Composite" device like you are showing on your computer. I also have four USB ports, with one for mouse and one for the Tascam soundcard.
I am running Java jre1.6.0_06, which is version 6, update 6.
In the Tascam control panel, I have no option to turn off the digital output format. As shown below, there is only S/PDIF (which worked for me when running XP) and AES/EBU. AES/EBU doesn't work either when I try it, but it does change the Java icon on the Vista Volume Mixer to "Settings".
Name:  Tascam Control Panel.jpg
Old 06-26-08, 06:07 PM   #55
Alias: brucek
User: #6
  brucek is offline
hehehe, I'm afraid I'm out of ideas............
Old 06-26-08, 07:34 PM   #56
tickertape
Inactive
Alias:
User: #
Posts: n/a
OK, well, thanks for all your help.
Guess I'll just go back to the XP machine.
Old 06-27-08, 08:16 AM   #57
Alias: brucek
User: #6
  brucek is offline
By the way, I guess you tried the "Delete Settings and Shut Down" routine under the Settings pull down in REW? It clears all the settings and starts fresh?
Old 06-27-08, 12:30 PM   #58
tickertape
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
I just tried Delete Settings and Shut Down," and for the first time (on the Vista system), there was -12dB level shown on the output VU meter in the Settings window. But it still did not make it out to the speakers (or headphones) attached to the Tascam.
So I created a debug file then configured everything back over to the XP system, mainly to see if it was still working. Everything does still work correctly on XP, so I created a debug file there to compare with the one created on the Vista configuration. There are differences, especially in some of the I/O settings, but nothing that hasn't been tried during troubleshooting.
Name:  debug compare.jpg
The lower of the two files is the XP system (that works), and the upper is the Vista config.
Would it help if I sent you both complete files ?
Old 06-27-08, 02:09 PM   #59
Alias: brucek
User: #6
  brucek is offline
Just embed the text in a post with code on / code off tags, such as I do below.
That way John can see them too. He's far better at reading debug info...
Here's my Vista Laptop debug using USB soundcard Audio Advantage SRM.
Code:
SoundCard Debug Data generated by Room EQ Wizard V4.11
Dated: 27-Jun-2008 1:55:55 PM
Input Device: Line In (Audio Advantage SRM De
Input: LINE_IN (Master Volume)
Input Volume: 0.251
Output Device: Speakers (Audio Advantage SRM Device)
Output: No output selected
Output Volume: No control
Output Mute: Off
Wave Volume: No control
Wave Mute: Off
0: Primary Sound Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
  Line interface SourceDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
  0: PCM_UNSIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame,  (1 channels, frameSize=1, little endian)
  1: PCM_SIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame,  (1 channels, frameSize=1, little endian)
  2: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, little-endian (1 channels, frameSize=2, little endian)
  3: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, big-endian (1 channels, frameSize=2, big endian)
  4: PCM_UNSIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame,  (2 channels, frameSize=2, little endian)
  5: PCM_SIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame,  (2 channels, frameSize=2, little endian)
  6: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
  7: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, big-endian (2 channels, frameSize=4, big endian)
    Controls[0]: FloatControl: Master Gain with current value: 0.0 dB (range: -80.0 - 6.0206)
    Controls[1]: BooleanControl: Mute Control with current value: False
    Controls[2]: FloatControl: Balance with current value: 0.0  (range: -1.0 - 1.0)
    Controls[3]: FloatControl: Pan with current value: 0.0  (range: -1.0 - 1.0)
  Line interface Clip supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
    [no controls]
1: Speakers (Audio Advantage SRM Device), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
    [no controls]
2: Speakers (Conexant High Definition SmartAudio 221), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
    [no controls]
3: Digital Output (Audio Advantage SRM Device), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
    [no controls]
4: SPDIF Interface (Conexant High Definition SmartAudio 221), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
    [no controls]
5: Primary Sound Capture Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
  Line interface TargetDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
    [no controls]
6: Line In (Audio Advantage SRM De, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
LineUnavailableException when trying to open this line
    [no controls]
7: Microphone (Audio Advantage SRM, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
    [no controls]
8: Microphone (Conexant High Defin, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
    [no controls]
9: SPDIF In (Audio Advantage SRM D, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
    [no controls]
10: Java Sound Audio Engine, Sun Microsystems, 1.0, Software mixer and synthesizer
  Line interface SourceDataLine supporting 8 audio formats (max. 32 simultaneously):
  0: PCM_SIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame,  (1 channels, frameSize=1, little endian)
  1: PCM_UNSIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame,  (1 channels, frameSize=1, little endian)
  2: PCM_SIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame,  (2 channels, frameSize=2, little endian)
  3: PCM_UNSIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame,  (2 channels, frameSize=2, little endian)
  4: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, big-endian (1 channels, frameSize=2, big endian)
  5: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, little-endian (1 channels, frameSize=2, little endian)
  6: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, big-endian (2 channels, frameSize=4, big endian)
  7: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
    Controls[0]: FloatControl: Master Gain with current value: 0.0 dB (range: -80.0 - 13.9794)
    Controls[2]: FloatControl: Pan with current value: 0.0  (range: -1.0 - 1.0)
    Controls[3]: FloatControl: Sample Rate with current value: 44100.0 FPS (range: 0.0 - 48000.0)
  Line interface Clip supporting 8 audio formats, and buffers of 0 to 4194304 bytes (max. 32 simultaneously):
11: Port Speakers (Audio Advantage SRM D, Unknown Vendor, 6.0, Port Mixer
  Port SPEAKER target port
    Controls[0]: BooleanControl: Mute Control with current value: false
    Controls[1]: FloatControl: Volume with current value: 1.0  (range: 0.0 - 1.0)
    Controls[2]: CompoundControl: CD Audio Control containing Mute, and Volume Controls.
      MemberControls[0]: BooleanControl: Mute Control with current value: false
      MemberControls[1]: FloatControl: Volume with current value: 1.0  (range: 0.0 - 1.0)
    Controls[3]: CompoundControl: Master Volume Control containing Mute, and Volume Controls.
12: Port Speakers (Conexant High Definit, Unknown Vendor, 6.0, Port Mixer
13: Port Digital Output (Audio Advantage, Unknown Vendor, 6.0, Port Mixer
  Port Master Volume target port
14: Port SPDIF Interface (Conexant High , Unknown Vendor, 6.0, Port Mixer
15: Port Line In (Audio Advantage SRM De, Unknown Vendor, 6.0, Port Mixer
  Port LINE_IN source port
    Controls[0]: CompoundControl: Master Volume Control containing Mute, and Volume Controls.
      MemberControls[0]: BooleanControl: Mute Control with current value: true
      MemberControls[1]: FloatControl: Volume with current value: 0.25119403  (range: 0.0 - 1.0)
    Controls[2]: CompoundControl: Master Volume Control containing Mute, and Volume Controls.
16: Port Microphone (Audio Advantage SRM, Unknown Vendor, 6.0, Port Mixer
  Port MICROPHONE source port
      MemberControls[1]: FloatControl: Volume with current value: 0.0  (range: 0.0 - 1.0)
17: Port Microphone (Conexant High Defin, Unknown Vendor, 6.0, Port Mixer
18: Port SPDIF In (Audio Advantage SRM D, Unknown Vendor, 6.0, Port Mixer
  Port Master Volume source port
I also see in a Tascam site pdf on your card it says in part:
· The US-144's digital input will not be available if the clock mode in the control panel is set to "Internal".
To use the digital input, set the clock mode to "Automatic” so the US-144 will clock to the external device.
You have your card set to Automatic, so digital is on. Set it to Internal to turn digital off, and see if that makes any difference.
Old 06-27-08, 04:14 PM   #60
tickertape
Inactive
Alias:
User: #
Posts: n/a
I've tried setting it both ways; Internal and Automatic. Neither way works on the Vista configuration.
Here is the debug file from REW in my Vista configuration:
Code:
Dated: Jun 27, 2008 10:02:11 AM
Input Device: Line In (TASCAM US-144)
Input Volume: 0.000
Output Device: Speakers (TASCAM US-144)
Output: SPEAKER
Output Volume: 0.977
Output Mute: Off
Wave Mute: Off
    [no controls]
1: Speakers (TASCAM US-144), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
    [no controls]
2: Speakers (Realtek High Definition Audio), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
    [no controls]
3: Primary Sound Capture Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
    [no controls]
4: Line In (TASCAM US-144), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
    [no controls]
5: Microphone (Realtek High Definition Audio), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
    [no controls]
6: Java Sound Audio Engine, Sun Microsystems, 1.0, Software mixer and synthesizer
7: Port Speakers (TASCAM US-144), Unknown Vendor, 6.0, Port Mixer
    Controls[1]: FloatControl: Volume with current value: 0.97656214  (range: 0.0 - 1.0)
      MemberControls[1]: FloatControl: Volume with current value: 0.97656214  (range: 0.0 - 1.0)
8: Port Speakers (Realtek High Definiti, Unknown Vendor, 6.0, Port Mixer
9: Port Line In (TASCAM US-144), Unknown Vendor, 6.0, Port Mixer
10: Port Microphone (Realtek High Defini, Unknown Vendor, 6.0, Port Mixer
      MemberControls[1]: FloatControl: Volume with current value: 0.20920119  (range: 0.0 - 1.0)
Old 06-27-08, 05:03 PM   #61
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
It is strange that the debug utility is finding there is a Tascam line in volume control somewhere and it is set to zero, and also a master volume that is set to zero. If, with the input device, input, output device and output set to the Tascam, the boxes to control input and output volume can be selected then select them and make sure the volumes are set to 1.000.
Old 06-27-08, 07:26 PM   #62
tickertape
Inactive
Alias:
User: #
Posts: n/a
JohnM wrote: View Post
Like this ?
...still no output.
Old 06-27-08, 07:38 PM   #63
Alias: brucek
User: #6
  brucek is offline
Weird, weird, weird.....
I'm assuming that the card also doesn't work with any applications such as Windows Media player, etc. I assume even Windows Sounds doesn't work (that you show muted).
In other words, this isn't specific to REW. The card simply does not work with Vista (as claimed by the company).
I also assume, you have unloaded and then reloaded the Vista driver for the card.
Old 06-27-08, 09:13 PM   #64
tickertape
Inactive
Alias:
User: #
Posts: n/a
No, the card doesn't work, or rather, Windows Media Player doesn't work with the card.
I never saw anything from Tascam about the card not working with Vista, but then, I intended from the beginning to use it with XP. It was only after realizing how loud the fan was in the XP laptop that I decided to transfer it all to my Vista laptop.
The US-144 Resources page on the Tascam website shows drivers for XP and Vista, but does not differentiate between the two. I am running v1.11 for Windows 32-bit XP and 32-bit Vista, as shown in the window below, taken from the Tascam website's driver listings.
Where did you see that Vista was not supported ?
Old 06-28-08, 09:42 AM   #65
Alias: brucek
User: #6
  brucek is offline
hehe, I didn't. It was an assumption from a sample of one - you.......
Now I want to see someone else use this card with Vista and make it work.....
Old 06-28-08, 10:44 PM   #66
tickertape
Inactive
Alias:
User: #
Posts: n/a
Yeah...me too !
Old 06-16-09, 11:59 PM   #67
Alias: kjg
Loc: Wisconsin
User: #13467
Since: Nov 2007
  kjgarrison is offline
WELL??
