REW Forum
Can't get this to work !
Discuss Can't get this to work ! in the Equalization | Calibration forum; Can't get this to work ! Hi there, I apologize if this is not appropriate but I am having a lot of troubles getting ETF (not ...
Views: 1300 - Replies: 42
Old 08-02-06, 05:58 PM   #1
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Hi there,
I apologize if this is not appropriate but I am having a lot of troubles getting ETF (not room eq wizard) to work properly.
I have a Genuis value 5.1 card that I bought a few days ago and I bought the necessary cables. But when I run the measurments to test the sound card, there is a lot of noise.
The mixer settings are okay. And if I change the sampling rate from 44khz to 48khz, there is very little change. To make matters worse, the levels between left and right channels change quite a bit if I wiggle the cables a bit.
I have basically connected the left input to the left output and the right input to " " " just to test the sound card out. I have spoken to Doug and he is also a little unsure of what to do.
If I check the signal to noise ratio on the graph, it reads at best, 2 dB. Doug tells me that the reading should be around 20 dB.
Help !
--Sincerely,
Old 08-02-06, 07:36 PM   #2
Alias: Dan
Loc: Australia
User: #359
  Danny is offline
Re: Can't get this to work !
Vaughan Odendaal wrote:
Hi there,
If you have a question please ask, hopefully we'll be able to help you
Depending on the speakers in your system the change from 44khz and 48khz may be hard to hear. RE the cables it sounds to me like you have a dodgy connection somewhere, possibly in the cables but it also could be elsewhere (sound card, source etc) maybe try replacing the cables then go from there.
Hope this helps
D.
Old 08-03-06, 03:49 AM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Have you selected the Genius card to be your default device for sound playback and sound recording? (Audio tab of the Sounds and Audio Devices properties in the Control Panel). Which output are you using on the card? Although you say the mixer settings are OK, that is where many problems occur especially with multi-channel cards - does the Genius card have its own mixer? Maybe worth posting screenshots of the settings. What sort of cables are you using the make the loopback connection?
Old 08-03-06, 01:21 PM   #4
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Alright. Thanks for asking these questions. Let me be more specific. I am just the front out and line in connections to do a loop thru. I take a duel RCA male to male and plug into a duel female to 3.5 mm computer jack.
I don't know if you know of my sound card, but it was a low cost, cheap sound card and Doug from ETF told me that it should work. A number of other people I corresponded with said the same thing.
It is a full duplex card. And to answer your questions, yes, my sound card does have it's own seperate mixer. I'm not sure what that must be set to but I am also using the windows mixer. That is the main mixer that I am currently using.
What worries me is that the levels between right and left channels jump by about 4-5 dB with just a little wiggle from the cable. Now I've replaced these cables with much longer duel RCA's and the problem remains the same.
Perhaps it is the duel female to 3.5mm computer jack which is somehow corrupt ? I'm not sure. But Doug from ETF told me that he has never seen the kind of problems that I'm experiencing in his entire life.
That isn't good. I will post some measurements. Again, I apologize because I know that this forum is for room eq wizard. Does anyone have experience with this acoustic program ?
BTW, I also downloaded room eq wizard too. I will post some measurements to show you what I'm talking about. Thanks for wanting to help.
--Sincerely,
Old 08-03-06, 03:33 PM   #5
Alias: brucek
User: #6
  brucek is online now
Hard for us to know if you don't tell us what the sound card is?
Does your soundcard have the standard line-in and line-out stereo 1/8" jacks on it that either of the (1/8" stereo to RCA adapters) shown below can plug into?
If so, you would be better to use the wire type shown instead of the heavier adapters since they place much less strain on the soundcard connector. The connector on the soundcard is pitifully inadequate and prone to poor connectivity. The less strain you put on it the better.
As I remember, ETF use to require the loopback cable hooked up all the time during measurement (unlike REW that uses it once to obtain a compensation calibration file). Is it still this way?
It's a lot easier to use in my opinion.
Old 08-03-06, 03:47 PM   #6
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Thank for replying !
Sorry, it's called the "Genius Sound Maker Value 5.1".
Yes it does.
I have both of those adapters. The bottom adapter shown in the picture you posted I couldn't use to connect the duel RCA's because both my line in and front out are next to each other.
So it is impossible for me to use those connectors because of the width of the connector. So instead, a computer guy recommended that I use cables instead. So he made up a duel female to computer jack.
Thanks for the advice. I have tried the duel female to computer jacks and I've also tried using duel RCA male to male cables (6 m long) to do a loop thru. Both cables give the same result.
It is only required to test the sound card. Once sound card has been tested the loop thru is no longer needed.
Any advantages to ETF ? Can it measure to a better or similar resolution ? How do I do a sound card measurement with REW ? Is it the same way with ETF ? I'm not sure.
I conversed with Doug and he now thinks that my sound card could be at fault. According to him, "It just may be that this particular card will not work because it has separate oscillators for input & output. They may be using an old chipset to
keep the price low
I really do not want to buy another card. I just bought this one a few days ago.
Thanks.
--Sincerely,
Old 08-03-06, 04:05 PM   #7
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Worth checking the workmanship, might have a bad joint in that cable.
The left channel must always remain connected as a loopback with ETF.
REW measures to higher potential resolution, in both cases the resolution is dependent on the gate times you use - the longer the gate time, the higher the frequency resolution (simply reciprocal, 100ms gate time means 10Hz resolution, 1000ms gate means 1Hz etc. REW displays this figure for you). In most situations the measurement signal-to-noise cannot be made high enough for gate times much above 1 or 2 seconds. REW makes prettier waterfalls and makes it easier to read values from the graphs. ETF calculates many more acoustic parameters than REW. The help files explain how to make soundcard measurements etc, you can read them online here.
Old 08-03-06, 04:23 PM   #8
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Are you the man behind REW ?
--Sincerely ?
Old 08-03-06, 04:25 PM   #9
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
I don't understand what you mean by higher "potential" resolution. I have been told that ETF can resolve information down to 0.7 hz.
I don't know what kind of resolution REW resolves to. The one thing I don't like about ETF is that the graphs like a bit ugly. On the other hand, the graphs and colours on REW and RTA look much, much better.
--Sincerely,
Old 08-03-06, 04:27 PM   #10
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
How does one know if the cables are "okay" ? Thanks.
--Sincerely,
Old 08-03-06, 04:40 PM   #11
Alias: brucek
User: #6
As long as they are not molded type connectors, you can simply do a visual inspection once you unscrew the body from the plug to expose the wires. Ensure no shorts and that the connections are well soldered. The tougher connection is with the 1/8" stereo plug. They're small and friggy to solder and easy to make a mistake.
You of course can simply check them with a meter if you have one also.
Old 08-03-06, 05:01 PM   #12
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Do you mean a multimeter ? How does one check these things out ? Sorry, I'm not that experienced when it comes to checking cable consistency.
Thanks. Because I would like to try and find out what could be the cause of the bad noise in my graphs. There are a few things :
Either it's the sound card, the cable that connects to the computer jack, the mixer settings haven't somehow been set up properly, or perhaps my own sound card mixer (the mixer that comes with the card) needs to be disabled ?
Currently it's enabled.
How does one rule out these things ? Trying to be all Sherlock Holmes. Heh.
--Sincerely,
Old 08-03-06, 05:01 PM   #13
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Yes, that's me.
The internal processing resolution of REW is 0.366Hz when using a 48k sample rate. This is determined by the FFT lengths used when generating the frequency responses, 128K in REW's case. However, the true resolution of a frequency response plot is determined by the duration of the section of the impulse response analysed to produce it. For 0.366Hz resolution you need to analyse a 2.73s period of the impulse response (or 1.4s for 0.7Hz). If you only analyse a 100ms portion of the impulse response, the resulting frequency response has only 10Hz resolution, no matter how large an FFT you apply to the (padded) data. To put this another way, you would not be able to see individual peaks that were less than 10Hz apart, they would be merged together. To have more time resolution you need to analyse a longer time period of the impulse response.
If you look at impulse responses, they are initially large and then decay away until they reach the noise floor of your measurement. Once the impulse response has fallen below the noise floor you can no longer use it to provide information about the frequency response, including data which is only noise degrades your frequency response result. To get the best frequency response, the impulse response is "windowed" to select the portion from the start of the response until it decays below the noise - this window is also referred to as a gate, and its length is referred to as the gate time. If the noise level is high, it may only be a few hundred milliseconds until the response is lost in the noise, so that measurement can never offer frequency resolution better than a few Hz. If the noise level is very low the response will be discernable for much longer and so you can use more of it and get higher frequency resolution.
The noise level in the impulse response can be reduced by using a higher sound level for the measurement sweep, ensuring the background (acoustic) noise is low, using pre-amplifers and soundcards with high signal-to-noise ratios, using longer sweep times and carrying out synchronous pre-averaging of multiple measurements (those last two will be available in the next release of REW, coming soon )
Old 08-03-06, 05:20 PM   #14
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
John, I'm glad I'm speaking to the guy behind the software. It helps matters greatly.
So with REW, I need to check sound card FR using my SPL meter ? Is there any other way of testing REW just for sound card problems without using an SPL meter ?
I have one but I don't think I have the necessary cables to do the test. I have two RCA male to male cables (to connect left and right front out and line in) and two female to computer jack cables that allow me to rig up the RCA's.
John, I need to ask you a question ; what is the cost of REW ? I downloaded the demo version I assume. Concerning the steps that I need to take to take the quality of the sound card out of the equation, what would I need to do ?
Thanks for your advice.
--Sincerely,
Old 08-03-06, 06:49 PM   #15
Alias: brucek
User: #6
Yes, a multimeter on the lowest resistance setting, checking for continuity and opens and shorts. Test that the sleeve of each RCA connects to the sleeve of the 1/8" stereo plug and isn't shorted to the center pin of either RCA plug or either the tip or ring of the 1/8" stereo plug. Check that the tip of the 1/8" stereo plug connects to the center pin of one RCA plug and no other and check that the ring of the of the 1/8" stereo plug connects to the center pin of the other RCA plug and no other......
No, you check the soundcard response by shorting one channel of the soundcards output to its input and saving a calibration file for the soundcard (after a special test) to be used every time you use REW. See the HELP FILES on calibrating the soundcard. In fact, read the entire HELP file and all your questions will be answered...
The total cost is zero. You downloaded the full version.
Old 08-03-06, 08:32 PM   #16
Owner
Loc: L.A. (Lower Bama)
Now why did you go and tell him it's free. Let me handle this please...
Vaughan... how much are you willing to pay? I'm sure we can work out an affordable payment schedule.
Old 08-04-06, 01:19 PM   #17
Alias: Royce
Loc: Victorville, CA
User: #49
  RollsRoyce is offline
Smile Re: Can't get this to work !
It's also possible that the receptacles on the sound card have lots of play and aren't making firm contact with the plug when it's inserted. Depending on the construction of the receptacles-some are open and some are enclosed-you may be able to carefully bend the side contacts in a little with a small screwdriver. Just enough to firmly grip the plug. It's easier to do this with the card removed, which will also make sure you don't short anything out. Look for cold solder joints where the receptacles are attached to the sound card. Good solder joints look smooth and shiny, while cold joints are usually dull and/or dark. Sometimes there will be a tiny ring in the solder around the pin.
---Royce---
"I never drink...wine..." Bela Lugosi, DRACULA, 1931
Old 08-04-06, 01:19 PM   #18
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Can REW measure modal ringing too ?
I just wanted to ask you, or John something. How would I be able to rule out the sound card as the culprit for the bad measurements ? Because I may buy another card. The salesman that sold me the card told me that I could return it, so I might get the Sound Blaster Live Value 5.1 card.
But that card is 2.5 times the price. Please give me some steps to check so that I know for certain that my card is not up for the task. Thank you very much !
--Sincerely,
Old 08-04-06, 02:07 PM   #19
Alias: brucek
User: #6
REW calculates both Spectral decay and Waterfall Plots. Waterfall plots reveal modal ringing. Please see the HELP FILES.
If it is full duplex and has line-in and line-out stereo connectors, then it's up to the task. Thats what the soundcard calibration file is for. See the HELP FILES on calibrating the sound card...
Old 08-04-06, 02:20 PM   #20
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Yeah, my card is full duplex. But the readings that my card is giving me is wacked out. There is noise on the flat line in the graph in ETF. There shouldn't be.
Perhaps I should measure my sound card with REW to show you. I read through the help but I would still like a little help to get me ready to get my sound card calibrated. I do want to show you the results as quickly as possible and I could use as much help as I can get.
I have the cables (I think). If I do a loop thru with REW and go test sound card, it tells me that I must set the levels for my SPL meter. I don't have to do that with ETF.
I was under the impression that the SPL meter would only come into play when measuring the actual room, and not just the sound card.
So basically, it's like this; if I connect the left input to left output and right input to right output then what exactly do I need to do next ? The mixer settings as described in the help file is self explanatory but then what do I need to do to test the sound card ?
I'm really sorry if I'm messing you around, but sometimes I like to get confirmation on what I'm supposed to do. A nasty habit I suppose.
Thanks a lot !
PS (John, if you're there, how would the Sound Blaster Live Value 5.1 sound card work ? Is it a good card to buy, if, indeed, my card is messed up ? )
--Sincerely,
Old 08-04-06, 02:57 PM   #21
Alias: brucek
User: #6
That's correct. Sounds like you may have the card in a monitor mode where the line-out is being fed back to the line-in. Don't be so quick to discard the soundcard. Find the fault and you'll be fine.
As you say, why not use REW since we're a lot more knowledgeable about it. I'm sure we can solve your problem and save you some money.
Nope. You do not connect left to left and right to right. REW always uses one channel only. The soundcard is first setup with a short from output to input and then a soundcard calibration file is saved. After that we remove the short and the saved file is then used by REW to compensate for any inadequacies in the soundcard and so we only input and output on a single channel (but we still need to use stereo adapters on the card itself), as shown below.
I sure wish I could get you to read those Help files, but in lieu of that I will direct you to a step by step use of REW I posted a while back. Specifically it will get you through the soundcard setup anyway.
READ THIS PART OF THIS THREAD
Old 08-04-06, 03:07 PM   #22
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Thanks !
--Sincerely,
Old 08-04-06, 03:45 PM   #23
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
Okay. I did as you suggested. I connected the right input to right output. I clicked "sound card calibration" and used the default setting -6 db. I also used the settings recommended in the help file to set the levels in playback and recording windows.
Right. I am getting quite a bit of noise in the graph. I'll post a pic in a few minutes. I need to find a way to post pictures quickly. I'm using imageshack to host files.
Thanks.
--Sincerely,
Old 08-04-06, 04:00 PM   #24
Alias: brucek
User: #6
Here's a step by step of how to post an image here at the Shack.
I bet there is a monitor loopback in the mixer settings somewhere..
Old 08-04-06, 04:14 PM   #25
Vaughan Odendaal
Inactive
Alias:
User: #
Posts: n/a
I also tried changing channels. Just to see what would happen. So I tried the left channel in the menu and changed the cables as well.
It told me that the input channel had a RMS value of -35 which is higher than what it should be. It says "it may be that the sound card has high amounts of noise".
With the right channel, it does not say this.
I tried the measurements again and this time the result was flatter with less noise. I don't know how and I don't know why, but the result is much better than what it was.
--Sincerely,
