REW Forum
Something's not right
Discuss Something's not right in the Equalization | Calibration forum; Something's not right Yes, another noob for REW and BFD. Here we go... Setup: HTPC with Realtek AC97 on board. Using the line ...
Views: 826 - Replies: 6
Old 08-03-06, 12:14 AM   #1
rsachs
Inactive
Alias:
User: #
Posts: n/a
Setup:
HTPC with Realtek AC97 on board. Using the line out and line in jacks.
Linein: mono input from RS Digital meter. Calibration file has been loaded.
Lineout: Stereo 1/8" to left and right RCAs. Right side RCA to mono-to dual RCA to left and right aux inputs on receiver. The receiver is a high end Onkyo with basis bass management.
REW: Have the Realtek "speaker" selected for line out, and Realtek "stereo mix" for input.
Calibration has been run with levels all set as instructed, no errors arising. The soundcard calibration file looks correct as shown in the examples, and is loaded. When I did the various input/output calibrations I selected "Speaker" not sub or external.
For the Equaliser menu I have "generic" selected right now, as I'm not going through my BFD. My first attempt was to measure the main speakers.
Here is the problem: I select Left channel in the Channel selection pane, with "full range" selected. I run automatic measurement, with sweep 10 to 20k. Problem: I get a totally flat response as shown on the attached.
Same thing happens for right or sub. Clearly, this is not possible so I must be doing something wrong.
I note that the levels shown in the filter panel are at 78dB; this is quite different from the example shown in the help pages under automatic measurement.
Any guidance from the pro's would be great.
Thanks in advance,
Bob
Old 08-03-06, 03:41 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Something's not right
Problem is your input selection, "Stereo Mix" is an internal loopback of your soundcard's output so your input is being fed directly from the output. You need to select "Line In" or similar so REW can see the signal from the SPL meter.
Old 08-03-06, 04:53 AM   #3
Alias: brucek
User: #6
  brucek is online now
You also need a stereo 1/8" to left and right adapter on the line-in. Then plug the RS meter into the right channel. The jack is a stereo connector, so the plug must also be stereo, even though you only use one side.
Also see this sticky on posting graphs and axis limits. Also best to turn on the grid lines.
sweep 10 to 20k
Note that your response above 10K will be quite inaccurate with a RS meter. Best to measure from 10Hz to 10KHz at best.
As John says... Here's a pic.
Old 08-03-06, 12:18 PM   #4
rsachs
Inactive
Alias:
User: #
Posts: n/a
Thanks to both of you. I tried the line in before but then I got the "input volume too low" error when setting the input volume. But that probably is because adapter issue.
I'll get the adapter plug going and see if we get somewhere.
Again, thanks...(and nice Elise John )
Old 08-03-06, 12:26 PM   #5
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Close...it's an Exige 240R
Old 08-03-06, 12:31 PM   #6
rsachs
Inactive
Alias:
User: #
Posts: n/a
Now we're talking!
It think it would be very hard to stay indoors watching movies when the Lotus is in the driveway.
Then again...I'm picking up a Cayman S this weekend ...two passions are better than one.
Old 09-30-06, 05:02 PM   #7
Alias: Gard
User: #2420
Since: Sep 2006
  Gard is offline
I need to bump this thread, since I have exactly the same problem. It's probably some loop somewhere or line-in just not working. I have to say that I'm trying this on an MCE XP so maybe it's some other app controlling the SC. I sure can't get responce from the mic via line-in, but it seems to get the generated signal from somewhere. I'm using the onboard AC97 on an Asus A8N32-SLI motherboard
This is what the chart looks like
