| REW Forum First measurements I dare to post!Discuss First measurements I dare to post! in the Equalization | Calibration forum; First measurements I dare to post! I have been playing with REW on and off for quite a while now and I have finally got to ... |
Views: 1954 - Replies: 64
| First measurements I dare to post! I have been playing with REW on and off for quite a while now and I have finally got to the stage where I dare post something. I am sure I could get some valueable pointers as to wether I am heading in the right direction. My setup is a HK AVR330, BDF2496, SVS SB12-Plus, and 5 x PMC DB1+ in a standard 5.1 HT setup based around a HTPC. I am using an ecm8000 microphone for measurements and feeding the test tones directly into the analogue input of the AVR330 set to stereo, surround off, no DSP. I have attached the measurements including the waterfall chart. All comments appreciated. I don't understand why the waterfall doesn't extend past 100Hz. There were several stages where I wasn't quite sure if I was doing the right thing:- ![]() First of all I played a film with a lot of LFE (U571) to increase the signal level to the BFD from the AVR330 so the BFD signal meter was all green and occasionally orange. That mean increasing the sub channel in output in the AVR330 to max (+10) when in Dolby Digital surround mode. However wwith the soundcard output was connected via the amp (stereo, surround off) I had to decrease the subwoofer channel output to stop clipping in the BFD. (With the AVR one has to set speaker levels for each surround mode.) After taking the measurements, setting the target level, and programming the filters generated I reset the subwoofer channel output to +10 and rebalanced the speakers, using the subwoofer gain control when it came to the sub. So how did I do? | ||||
| | #2 | ||||||
| Re: First measurements I dare to post! Quote:
A tip. There is a filter sort button (from low to high) on the filter panel. Very convenient to have your filters go from 1,2,3,4,5 instead of 3,2,1,4,6,5 ![]() brucek | ||||||
| | #3 | ||||
| Re: First measurements I dare to post! Thanks brucek, Here are the new graphs, the corrected curve using just filter 3, and the waterfall plotted on a log freq axis. The waterfall looks a lot uglier - but I am not sure how to interpret it. Any pointers? Thanks. | ||||
| | #4 | ||||
| Re: First measurements I dare to post! Basically you can consider it a frequency response graph with the added axis of time. Drag the waterfall slider back to 1 slice. Look familiar? It's the response graph. Now move to 2 slices. You're now looking 10msec later in time at the level of the signal (if window set to 300msec). By the time you get to 30 slices, you're looking at 300msec later. If any frequency is still at an audible level you'll still be hearing it - considered perhaps not good.. brucek | ||||
| | #6 | ||||
| Re: First measurements I dare to post! Thanks brucek and thewire for your comments. This time around I redid all the measurments (so they may not look identical). I set one filter at 58Hz and then redit the measurement with main speakers and sub (I balanced both to approx 75dB). I set the target level by setting speaker type to Full Range. With my mains I still have a peak at 58Hz so I suppose this is a room effect, or? Then I have some some sharp dips at 76Hz, 100Hz, and 177Hz. Are these anything to worry about? Should I filter the peak at 130 Hz? I have attached the waterfall - to your expert eyes does it indicate problems that I should look to remedy? | ||||
| | #8 | ||||||||
Anyway, you have a classic example of how correcting a single peak can really help out. Look at your peak at 58Hz. You have correctly set the level matching between the sub and mains as a result of the peak at 58Hz. It overpowers and results in one-note bass. You can't turn up the sub or it will sound overpowering. But, if you remove that peak, then you are able to wholesale turn up your bass level, and as a result, the frequencies between 20Hz and 45Hz that were previously hidden, are now revealed and you feel like you just got a new sub...... brucek | ||||||||
| | #9 | ||||
| Re: First measurements I dare to post! Ok, I'll do another measurment with sub pink noise,etc. What's the best way for me to remove that peak now? As I have one filter set already at 58Hz if I automatically add another filter at 58Hz will the BFD sum them correctly? | ||||
| | #10 | |||||
brucek | |||||
| | #12 | ||||
| Re: First measurements I dare to post! Interesting. What is your crossover frequency? Can you take a mains only measure from 0-200Hz and post it? (just shut off the sub). brucek | ||||
| | #13 | ||||
| Re: First measurements I dare to post! I normally use small but with this amp when in stereo, no surround, no dsp mode the speakers can only be set to large. However there is a X-Over mode which is set at 80Hz and has the exactly the same measurment signature. That peak is at exactly the same freq as for the subwoofer i.e. 58Hz. | ||||
| | #14 | ||||
| Re: First measurements I dare to post! I redid the mains only measurment with the amp set to stereo, DSP ON, SMALL This produced a very different result... still a peak at 58Hz though Last edited by entrecour; 06-15-08 at 12:00 PM.. Reason: addition | ||||
| | #15 | ||||
| Re: First measurements I dare to post! OK, you've definitely got a large resonant peak at 58Hz. You may have to over compensate your equalizing a bit with the subs 58Hz filter. Hopefully you can lower it somewhat below the target and then the sum of that and the mains peak will be a better result. I would also increase the level of the sub somewhat in relation to the mains so that the level around the 30Hz region was at least equal to the level of the mains. To get a better feel for the overall level of the mains, take a measure of the mains only from 100Hz-1000Hz (use full range type here) and then turn on smoothing ~1/3 octave and see what the overall level is and then bring the sub up to that level at least. I think your sub is a bit low. brucek | ||||
| | #16 | ||||
| Re: First measurements I dare to post! Thanks for the pointers. Here are the new measurments The first measurment is sub only, no filters. The 2nd measurement is sub & mains with 1 filter at 58Hz. I ended up using the auto filter generated by REQ (58.35Hz, Gain -12, BW 0.25). Main speakers set to SMALL. Do you think the sub is high enough now. I have clipping in the measurments if I turn it much higher. Thanks! ![]() | ||||
| | #17 | ||||
| Re: First measurements I dare to post! Yeah, that's starting to look a lot better. I might add a filter at ~45Hz and turn the sub up a touch more. BTW, you won't have clipping in the measurements if you simply go through the Check Levels and Calibrate SPL routine of resetting REW back to 75dB. brucek | ||||
| | #19 | ||||
| Re: First measurements I dare to post! And here is the corresponding waterfall chart. I increased the Time Range to 900ms, and kept the Window to 300ms. Looks like there are some strange things going on around 25Hz! Should I be looking at room treatments (perhaps to address the slight dip at 36Hz) or are these kind of delays normal? | ||||
| | #20 | ||||||
No amount of treatment will affect as low as a 36Hz dip. That has to be attacked by positioning usually and then sometimes you have to live with it if positioning isn't possible. Quote:
I wouldn't look at a waterfall much more than a 600ms time axis. Anyway, you haven't said if it sounds any better? brucek | ||||||
| | #21 | |||||
More listening required before I can give a final verdict.However I have noticed some stubborn mechanical vibrations in the room as I am doing the sweeps (one long side wall is virtually all windows with venetian blinds) and I think a wall or the floor is vibrating somewhere. So probably some tweaking to do still - that's what I was hoping the waterfall might pinpoint. I also have to check what the background room noises might be. | |||||
| | #22 | ||||||
Pictures are the worst I find. I put little pads in the bottom corners of the picture where it contacts the wall. Fireplace doors are horribly noisy also. Hehe, this is what happens when you reveal the super low frequencies. It adds all sorts of vibration problems. It's like when you first get a high end system and then you hear all the horrible recordings you own. Quote:
Spectrum Analyser - no sine wave stimulus ![]() brucek | ||||||
| | #25 | |||||
| Re: First measurements I dare to post! Thanks, that was interesting reading. I also noticed this Quote:
I found it very difficult to choose the "best" phase. What should you aim for - the one that has the highest overall volume or the one that is the smoothest? | |||||
