| REW Forum Here's my measurement !Discuss Here's my measurement ! in the Equalization | Calibration forum; Here's my measurement ! only the tc-10oem in .78cu.ft sealed with LP Butterworth 24db/oct at 90hz playing:
only the b&w 685 full range playing:
Views: 387 - Replies: 3
| | #2 | ||||
| Re: Here's my measurement ! Please post your graphs with a vertical scale of 45dB-105dB and a horizontal scale starting at 15Hz. See the little icon in the bottom left corner of your graphs in REW? That's the button to save the graphs to a 800pix wide jpeg that is used to post plots (instead of showing a huge picture of REW). With that in mind, show us the sub from 15Hz-200Hz (no smoothing) and then a sub+mains from 15Hz-20Khz with 1/3 smoothing. ![]() brucek | ||||
| | #4 | ||||
| Re: Here's my measurement ! Looks like you need to do some adjusting of the phase of the sub to get a smoother transition around the crossover area. It's a fair dip between 60Hz-100Hz that isn't really present with the sub alone - indicating an interaction when the mains are added. Try phase and also time delay if required. I'm wondering why you're measuring at such a high level and not at 75dB? brucek | ||||
