REW Forum
REW accuracy?
Discuss REW accuracy? in the Equalization | Calibration forum; REW accuracy? I've just discovered REW. Looks like a great program. Has anyone compared it's accuracy against other programs (such as ETF, ...
Views: 655 - Replies: 8
Old 06-23-08, 05:16 AM   #1
bjs
Alias: bjs
Loc: Vancouver, BC
User: #21868
Since: Jun 2008
  bjs is offline
REW accuracy?
Has anyone compared it's accuracy against other programs (such as ETF, RDplus, ARTA, Praxis etc) or indepently confirmed it's validity?
I hope I'm not burned at the stake for asking such an impertinent question...but curiosity knows no limits...!
Old 06-23-08, 01:42 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: REW accuracy?
I'll leave the technical confimation to JohnM, the prolific creator of the program. I'll just say: Thousands of satisfied users, does that count? At least one manufacturer is using REW graphs on their website.
Old 06-23-08, 02:22 PM   #3
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: REW accuracy?
Yes, haven't played with Praxis but I have checked against the others mentioned and some more besides.
Old 06-23-08, 02:29 PM   #4
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
Re: REW accuracy?
I use RplusD and REW and found that the biggest differences are in the features. FR measurements are very close and the waterfalls appear to be just a bit different. I have leaned more to RplusD only because I have used it longer but now that I haven't been able to run it under MS Vista (others have no problem with that issue), I have been using REW more. As I originally said, each have some very good features that would be nice to have combined in one package.
Bob
"There is always hope, even if it is just a fool's hope."
Old 06-23-08, 06:22 PM   #5
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: REW accuracy?
Bob_99 wrote: View Post
You may not have come across this in the REW help: ETF users should note that ETF gate times are specified in a different manner to REW window durations, to convert an ETF gate time to the approximately equivalent window width, multiply by 1.4. That also applies to RplusD.
Old 06-24-08, 07:12 AM   #6
Alias: Bob_99
Bob_99's Avatar
Loc: New Hampshire
User: #460
  Bob_99 is offline
Re: REW accuracy?
Thank you, John. I've read the manual but obviously missed that information. Also, let me add my thanks to all the others for an amazing program. The fruit of your labor is very much appreciated.
Bob
Old 06-27-08, 11:32 AM   #7
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
Re: REW accuracy?
I've taken my measurement rig into the Klipsch anechoic chamber over in Indianapolis and my measurement was within 0.5dB from something like 100Hz to 10kHz.
They're using Leap and TEF.
I also get comparable results to Praxis.
Ultimately, the accuracy of REW depends on the accuracy of your soundcard. If your noise floor and distortion are low, then you'll get a fairly accurate measaurement. Usually the microphone is going to be the limiting factor in this case...
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 03-23-09, 02:17 PM   #8
Alias: jlohl
User: #9386
Since: Jun 2007
  jlohl is offline
Re: REW accuracy?
Thanks, this is written in the REW manual but could JohnM explain why are those gate times not equivalent ?
Old 03-23-09, 05:29 PM   #9
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: REW accuracy?
jlohl wrote: View Post
You'll have to ask Doug Plumb, I don't recall there being a way to plot what window extent a particular gate time gives in ETF or R+D so can't tell how the figure is used there. In REW you can see the window shape on the Impulse Response graph, the widths of the windows are the times you set.
