REW Forum
3channel EQ?
Discuss 3channel EQ? in the Equalization | Calibration forum; 3channel EQ? My front speakers, left/right, has a power woofer. The speaker's FR is rated down to 27Hz. However, the receiver is ...
Views: 295 - Replies: 3
Old 06-26-08, 01:47 PM   #1
Alias: marcus
Loc: Houston, tx
User: #7534
Since: Mar 2007
  udaman is offline
3channel EQ?
My front speakers, left/right, has a power woofer. The speaker's FR is rated down to 27Hz. However, the receiver is crossover at 60Hz with speakers set to 'small'. I also, have a 15" sub. I'm thinking of using EQ for the speakers and the sub as well.
I think I may need two BFDs - one for left/right and one for the sub.
or
Use Audiocontrol Bijou or Rane THX? It's quite expensive and I'm not sure if does the same thing as BFD.
So my question is there a cheap effective ways of EQing the left/right and sub?
Old 06-26-08, 01:53 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: 3channel EQ?
With the risk of some people disagreeing with me, I don't consider the BFD as audiophile quality and would resist the temptation to use it on your mains.
What is it you intend to "equalize" with respect to the mains. Anything above a few hundred hertz would require fairly low Q filtering (such as a graphic EQ might provide). If you have you speakers set to small, then the area below 60Hz wouldn't benefit too much from EQ.....
Old 06-26-08, 02:00 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: 3channel EQ?
Marcus, Are you using an external amp on your mains? If not you wont be able to hook up any sort of EQ to do the adjustments you ask.
Bruce is right, your far better off using a true Pro grade 1/3 octave stereo EQ on your mains for your sub the BFD would be ok.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-26-08, 02:08 PM   #4
Alias: marcus
Loc: Houston, tx
User: #7534
Since: Mar 2007
  udaman is offline
Re: 3channel EQ?
I was thinking of letting the sub handle anything below 60Hz and the speaker's sub handle the midbass - 60Hz - 150Hz). I have to run REW again but remember having a few 'highs', one at 40Hz and another at 80 - 90Hz. I thought of EQing the mains for the 60 - 150Hz range.
The bass is pretty good right now. But you know how it is, always trying to reach the 'holy grail'.
I have Yamaha v661 as pre/pro with LPA1 amp, speakers - Strata Mini.
thanks,
Marcus
