REW Forum
onkyo mic for rew?
Discuss onkyo mic for rew? in the Equalization | Calibration forum; onkyo mic for rew? Can I use the calibration mic that came with my onkyo 605 to run rew into my laptop?...
Views: 573 - Replies: 3
Old 07-02-08, 08:14 AM   #1
Alias: Dave
Loc: Bloomington, Illinois
User: #9307
Since: Jun 2007
  chopperguy99 is offline
onkyo mic for rew?
Old 07-02-08, 11:51 AM   #2
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
  mrsollars is offline
Re: onkyo mic for rew?
not trying to jump it.....but i was just getting ready to post the EXACT same question for my new Yamaha V663.
so.....can we?
Old 07-02-08, 12:30 PM   #3
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
The problem is that cheap mics like those supplied with a receiver do not have perfectly flat response. Therefore, in order to compensate for the mic's shortcomings, a calibration file is required to ensure accurate measurements with REW. In fact, the receivers also have built-in compensation for the mics they come with - that's why you don't get accurate results by using a Yamaha mic with a Onkyo receiver, for instance.
If you can get a frequency response graph of the mic, it's easy enough to create a calibration file. We've done the same thing for the Radio Shack SPL meters and Behringer mics we typically use with REW. That's not hard to do if you're using a mic from a know manufacturer, such as Shure or AKG. However, I expect that will be difficult with a receiver's mic, if not impossible.
You need an SPL meter to use REW anyway, because you can't set levels without it. That pretty much renders the question moot...
Old 07-02-08, 01:06 PM   #4
Alias: Dave
User: #9307
Since: Jun 2007
Thanks for the quick response! My onkyo set up my distances and x-over points pretty much right on, and the mains, center and surrounds sound pretty good, but I would like to confirm what it did, and I dont think the 605 does anything with the sub parametric. I definately have some peaks and valleys I would like to address. I am going to purchase the behringer dsp and mic for my PA eventually, so I can use that. Thanks again.
