| REW Forum Which spectrum analyzer should I use?Discuss Which spectrum analyzer should I use? in the Equalization | Calibration forum; Which spectrum analyzer should I use? Hi there,
REQ is no doubt a fantastic tool for acoustic calibration, and it has made my work a lot ... |
Views: 690 - Replies: 5
| Which spectrum analyzer should I use? Hi there, REQ is no doubt a fantastic tool for acoustic calibration, and it has made my work a lot easier. However, in order to get more precise test results, I have been trying to use the PMI's 5.1 tool kit DVD. What I am trying to do is to get the measurement data from a spectrum analyzer and then import the data into the REQ. Then the question goes to which spectrum analyzer should I use. I have tried the ETF 5.X and found it difficult to use. Does REQ accept measurement data from any other spectrum analyzer? Which of the following analyzer works the best with the REQ? Goldline DSP30 Sencore SP295C Phonic PAA3 I look forward to some expert's help M | ||||
| | #2 | ||||
| Re: Which spectrum analyzer should I use? I do not know about importability with REW but you should look at TrueRTA. http://www.trueaudio.com/rta_abt1.htm Kal | ||||
| | #3 | ||||
| Re: Which spectrum analyzer should I use? Why not use the spectrum analyser in REW? REW Spectrum and RTA | ||||
| | #4 | ||||
| Re: Which spectrum analyzer should I use? cool....I just found that the new version of REW had this feature. What a wonderful tool!! Quetion, there are many options of window functions. How should I choose the window functions? M | ||||
| | #6 | ||||
| Re: Which spectrum analyzer should I use? Here is a direct link to the REW Spectrum help: http://www.hometheatershack.com/room....html#spectrum | ||||
