| REW Forum Cant select audio card !Discuss Cant select audio card ! in the Equalization | Calibration forum; Cant select audio card ! Hi !
Im new here im trying to run REW in my PC but i can select an audiocard !
Views: 390 - Replies: 6
| Cant select audio card ! Hi ! Im new here im trying to run REW in my PC but i can select an audiocard ! My sound card is a Digi003 mixer from digidesign ( Protools ) Ive already added REW to my card applications . Everytime i open REW it says : Audio interface error No input mixers avaiable No outout mixers avaiable Supporting PCM_SIGNED 44100.0Hz 16bit, stereo, 4 bytes/frame, little-endian. Any help ! Thanks | ||||
| | #2 | |||||
| Re: Cant select audio card ! Quote:
Welcome to the forum ![]() P.S.: Have you set up everything correctly on the computer??? ... try re-booting, sometimes that helps ![]() I just found this thread ... maybe it can help (is about digi002) http://www.hometheatershack.com/foru...igi-002-a.html Last edited by salvasol; 07-16-08 at 04:43 PM.. Reason: Add link | |||||
| | #3 | ||||
| Re: Cant select audio card ! What computer and operating system are you using? | ||||
| | #7 | ||||
| Re: Cant select audio card ! SPL meter acts as a microphone ... you don't need anything else. | ||||
