| REW Forum NullPointerException when starting RoomEQDiscuss NullPointerException when starting RoomEQ in the Equalization | Calibration forum; NullPointerException when starting RoomEQ Hi there:
excited to try out RoomEq, but when trying to start it up I got an NPE.
Using Windows ... |
Views: 402 - Replies: 5
| NullPointerException when starting RoomEQ Hi there: excited to try out RoomEq, but when trying to start it up I got an NPE. Using Windows XP Home, this happened under both Java 1.5.0_10 and 1.6.0_10 (I assume RommEq picks up the new version of java, which I installed after installing and running RoomEq the first time). Pops up during "adding menu items". Any thoughts? Looks like a Swing thing? Perhaps I need to reinstall java? Thanks! -Casey ---------------------------- Exception during startup Message: java.lang.NullPointerException Level: SEVERE Stack Trace: null javax.swing.ImageIcon.<init>(Unknown Source) javax.swing.ImageIcon.<init>(Unknown Source) sun.swing.WindowsPlacesBar.<init>(Unknown Source) com.sun.java.swing.plaf.windows.WindowsFileChooserUI.updateUseShellFolder(U nknown Source) com.sun.java.swing.plaf.windows.WindowsFileChooserUI.installComponents(Unkn own Source) javax.swing.plaf.basic.BasicFileChooserUI.installUI(Unknown Source) com.sun.java.swing.plaf.windows.WindowsFileChooserUI.installUI(Unknown Source) javax.swing.JComponent.setUI(Unknown Source) javax.swing.JFileChooser.updateUI(Unknown Source) javax.swing.JFileChooser.setup(Unknown Source) javax.swing.JFileChooser.<init>(Unknown Source) javax.swing.JFileChooser.<init>(Unknown Source) roomeqwizard.o$34.<init>(Unknown Source) roomeqwizard.o.I(Unknown Source) roomeqwizard.o.<init>(Unknown Source) roomeqwizard.UA.<init>(Unknown Source) roomeqwizard.RoomEQ_Wizard.main(Unknown Source) sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) java.lang.reflect.Method.invoke(Unknown Source) jexepackboot.run(Unknown Source) jexepackboot.main(Unknown Source) | ||||
| | #2 | ||||
| Re: NullPointerException when starting RoomEQ To verify that Java is installed correctly, try this link. http://www.java.com/en/download/inst...tect=jre&try=1 | ||||
| | #3 | ||||
| Re: NullPointerException when starting RoomEQ Are you running a non-standard Windows theme? The Java look and feel can crash with null pointer exceptions when there are 3rd party themes installed, if that is the problem reverting to a standard Windows theme would fix it. | ||||
| | #4 | |||||
| Re: NullPointerException when starting RoomEQ Quote:
Perhaps an addition to the REW setup and/or FAQ is in order? I don't have any third-party stuff, just customized some window sizes/colors, etc. Seems like that would be pretty common. Thanks again! -Casey | |||||
| | #5 | ||||
| Re: NullPointerException when starting RoomEQ Ah, but add this to the mix. What I did was: - follow the link suggested by the first poster, which "updated" my plugins to the current java version, although I believe everything was installed correctly before, but who knows - "save"d my theme - switched to the default windows XP theme - ran REW (success) - switched back to my theme - ran REW again, and guess what: success (where before there was only failure :-) ) So it was either that the "update" did it, that the switching of the themes reset some value, or that the switching of the themes did not maintain every strange quirk of my theme when I "save"d it, and one of those quirks was lost in the switching back and forth. I mention all this for the sake of posterity, in case someone searches for the solution I found. Thanks, -c | ||||
| | #6 | ||||
| Re: NullPointerException when starting RoomEQ Hi! I have the same problem under vista ultimate x64 ![]() " Exception during startup Message: java.lang.NullPointerException Level: SEVERE Stack Trace: null roomeqwizard.UA.C(Unknown Source) roomeqwizard.UA.<init>(Unknown Source) roomeqwizard.RoomEQ_Wizard.main(Unknown Source) sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) java.lang.reflect.Method.invoke(Unknown Source) jexepackboot.run(Unknown Source) jexepackboot.main(Unknown Source) " using java 6.0 u12. i tried to change theme, compatibility mode, run as admin but no solving... can anyone help me please? or maybe suggest another similar program to calibrate my 5.1? please ![]() | ||||
| Bookmarks |
| Tags |
| nullpointerexception, roomeq, starting |
| Thread Tools | |
