REW Forum
Over the first hump (I think)
Discuss Over the first hump (I think) in the Equalization | Calibration forum; Over the first hump (I think) Some of us are slower then others..... But, I believe I have generated a few graphs for the experts to ...
Views: 342 - Replies: 4
Old 07-17-08, 07:47 PM   #1
New Member
Alias: Brian
User: #20565
Since: May 2008
  brotsten is offline
Some of us are slower then others..... But, I believe I have generated a few graphs for the experts to have a look at.
I'm working on a dedicated theater, 34'Lx16'Wx10'H.
The sub, a Danley DT20 is located in the rear of the theater, laying horizontal, centered on a stage that is ~5'Lx16W about 10" high and filled with sand. The stage and walls have been treated with 1" thick duct liner for damping.
I calibrated my sound card per the help file.
I'm using an older RS SPL meter with your supplied cal file. Here is the first shot:
I ran the find peaks and created 12 filters that I uploaded to the FBQ2496. Here is a graph with both the filtered and unfiltered plots:
Name:  plain and filtered.jpg
What do you think?
Brian
Old 07-17-08, 08:37 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Over the first hump (I think)
Good job..
All the filters to the right of the crossover are likely not needed. After the crossover the level drops fairly rapidly and as the frequency increases the mains will overwhelm the situation, so you can limit your peaks find routine to about 90-100Hz.
A useful tip. There is a filter sort button on the filter popup screen. Numbers them from 1 to 12 (low to high).
I would address that notch at ~22Hz. I would first move the sub away from its center positioning.
I would remove all the filters (1, 6, 4, 11, 10, 12, 3). Then perhaps use one to lower the small peak at ~72Hz. Then add the mains and check how it looks around the crossover.
Old 07-19-08, 01:01 AM   #3
New Member
Alias: Brian
User: #20565
Since: May 2008
  brotsten is offline
I moved the sub to the corner, but that was only about 3 feet with it laying horizontal, so I also positioned it in a vertical orientation. That allowed another 4 feet of lateral placement.
I raised the volume about 10db as REW said it would be more accurate. Still only the sub.
Name:  run3 sub input.jpg
Post filtered:
Name:  run3 post filter.jpg
Brian
Old 07-19-08, 05:59 AM   #4
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
After you Assign Filters in REW click on "Optimise PK Gain & Q" to have REW adjust the filters for the best match to your measurement.
Old 07-19-08, 01:03 PM   #5
New Member
Alias: Brian
User: #20565
Since: May 2008
  brotsten is offline
I thought I did, but I will go back and recheck.
Brian
hump, think)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
