REW Forum
Tell me what you think.
Discuss Tell me what you think. in the Equalization | Calibration forum; Tell me what you think. I just installed a FBQ2496 This is my first EQ. This is after laying 3 different layers. I really dont ...
Views: 524 - Replies: 19
Old 07-18-08, 12:52 AM   #1
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
  devicente is offline
Name:  end result.jpg
I really dont like these results.
I dont have a MIDI, I entered it all manually.
I also added between a 3\60 and 5\60 on the band with, don't know really what to do with it.
Should i just start over? And how should i do this?
Please help!
Thanks.
Old 07-18-08, 09:40 AM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Tell me what you think.
Neither do I...
You need to redo your raw measure. It's not within a workable target.
It looks like you did everything correct, but I suspect you didn't click the Calibrate SPL button after you finished the Check Levels routine. Once the Check Level routine is finished, the actual level at the listening position is 75dBSPL as set by your SPL meter. Then we have to tell REW to set its internal meter to ~75dB as well (to match the two meters). That's what the Calibrate SPL routine does.
The top smooth part of your plot #1 is probably the 75dB mark and will end up around the target line. The target line is used to determine the filters.
Redo the measure and also this time use the standard vertical scale of 45dB-105dB and horizontal scale of 15Hz-200Hz. They are set with the Graph Limits button.
Once you've got a good raw measure, post it so we can see...
Old 07-18-08, 11:32 AM   #3
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
Yes I'll do that, The funny thing is that i did calabrate my SPL. I will retry then repost that result.
Old 07-18-08, 11:51 AM   #4
Alias: brucek
User: #6
Then you should run the Set Target Level routine to ensure your estimated level is consistent with the target line and creation of reasonable filters. You only need to look at that plot #1 and you know either the Calibrate SPL or Measured Target Level is way off.
Old 07-19-08, 06:17 PM   #5
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
This is Better i think.
This one is done with the Java Driver.
Attachment 8514
This one is the default driver. Not sure which to use.
Name:  default start.jpg
How should i do this.
Thanks
Old 07-20-08, 12:29 AM   #6
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
This is my final.
I had 2 valleys that i increased about 2-5 db each.
Old 07-20-08, 06:34 AM   #7
Alias: brucek
User: #6
Change your graph scaling to the standard vertical = 45dB-105dB and horizontal = 15Hz-200Hz
Old 07-21-08, 09:08 PM   #8
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
This is the final result for my start.
Tell me what you think. I purchased a Midi will any work? It is a UM-1EX, Edirol By Rolland. I also have a Mac book Pro. The Midi says it works with Mac but will it work with the FBQ2496
Name:  072108 start.jpg
And what can I expect from preformance from my RS SPL. Will it suffice?
Old 07-21-08, 09:27 PM   #9
Alias: brucek
User: #6
Yeah, looks good. I might try and move the sub around a bit to smooth it out if you can, but you can certainly help it with some equalization.
I think the USB to Midi interface cable that a lot of people use is this one. Just connect from the Computer USB to the BFD MIDI-IN port.
It's fine for sub measurements. I don't understand the question really. Are you not using it to measure now?
Old 07-22-08, 12:45 AM   #10
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
Do you have an example of what it should look like, or do you know where i could see some?
Old 07-22-08, 03:41 AM   #11
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
To use a Midi interface on the Mac with REW you will probably need software from Mandolane: http://www.mandolane.co.uk/index.html
Old 07-22-08, 07:22 AM   #12
Alias: brucek
User: #6
Sorry, I don't understand the question? Example of what?
Old 07-22-08, 10:16 AM   #13
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
What a sub wave should look like. What is my goal?
Old 07-22-08, 10:27 AM   #14
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
JohnM wrote: View Post
What is this software, do i really need it, what does it do, and which one do I down load, I see 4 I believe.
Thanks
Old 07-22-08, 10:30 AM   #15
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
The goal is to get smooth response down to 25 Hz, or even lower if your subwoofer is capable enough. As it is now, you're losing everything below ~35 Hz. It looks like your sub may be capable of getting below 20 Hz, if placed in a favorable location. Do you have a corner availible?
Old 07-22-08, 10:53 AM   #16
Alias: brucek
User: #6
With a PC you wouldn't require any special software, but with the MAC you need it. Either way, the midi connection is for those who don't feel like entering the REW suggested filters from the front panel of the equalizer and would rather do it with a cable download. Personally, I enter them by hand. Seriously, how often do you plan on doing it that you can't enter it by hand.
What is my goal?
See that blue target line on the graph, that you set to your crossover frequency? If your sub tracked that line, it would be a perfect world. Try your best within reason....
Old 07-22-08, 03:42 PM   #17
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
brucek wrote: View Post
You beat me with the answer
As Brucek said ... try to get your sub response as close as possible to the blue line, I little above or below the line is acceptable too
Old 07-22-08, 06:17 PM   #18
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
I is already in a corner.
This is my current layout.
Room set up 072208.pdf
Old 07-22-08, 09:20 PM   #19
Alias: Wayne
Loc: Katy, Texas
User: #8
Wow - can't remember when I've seen response that bad from a corner. Hopefully you had that slider door closed when you made the measurements? Is that front corner by the left speaker an option?
Old 07-27-08, 09:35 PM   #20
Alias: Steve
Loc: Bend, Oregon
User: #9843
Since: Jun 2007
This is my Final
What do you all think.
Name:  072708 final.jpg
Im not sure what to do with the Valley at the 30 HZ.
think.
