REW Forum
Soundcard setup and calibration
Discuss Soundcard setup and calibration in the Equalization | Calibration forum; Soundcard setup and calibration Been reading quite a bit on all the different types of hardware people are using trying to get an idea ...
Views: 377 - Replies: 2
Old 07-19-08, 03:04 AM   #1
New Member
Alias: kenrinc
Loc: CA
User: #15569
Since: Jan 2008
  kenrinc is offline
Been reading quite a bit on all the different types of hardware people are using trying to get an idea if REW will even work with what I have. I've got a Powermac G5 dual 2.0 PPC running OS 10.5.4 and REW v4.11 I have a MOTU 2408 mk3 interface that work flawlessly for my music recording stuff but when I'm having a time trying to calibrate it for REW.
I've been using the Defaults my card is set to 44.1k so I have REW set to 44.1 and the input and outputs set to default, partly because that's the only option (well there is Java audio for output and PCI-424 for input but those don't do anything). I loop the outputs of my 2408 to it's inputs and then go through the calibration. I've tried left and right channels (singly) and all I get is what sounds like a square wave (no 1k tone). I've tried nearly all combinations of selections but still can't figure it out. Any help appreciated.
Ken-
Old 07-19-08, 05:56 AM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Soundcard setup and calibration
There seems to be a problem with the Java PPC audio interface that results in audio data ending up byte-swapped, I'll try putting some workarounds into the next release to see if that can be corrected but I'm afraid that is some months away.
Old 07-19-08, 12:07 PM   #3
New Member
Alias: kenrinc
Loc: CA
User: #15569
Since: Jan 2008
  kenrinc is offline
Thanks John. Wasn't sure if that was the case or not.
Ken
calibration, setup, soundcard
