REW Forum
My First Measurement
Discuss My First Measurement in the Equalization | Calibration forum; My First Measurement Hi guys, After reading this forum for some time. Finally, this is my first measurement though I still haven't got ...
Views: 591 - Replies: 23
Old 07-19-08, 12:34 PM   #1
Alias: vocal mind
User: #21837
Since: Jun 2008
  vocalmind is offline
Hi guys,
After reading this forum for some time. Finally, this is my first measurement though I still haven't got BFD yet, here is my setup.
1. SB Live External
2. 7.1 input (sub) on the AVR
3. Subwoofer
I guess my room has some issues or is there something wrong on the above setup?
Waterfall
1/3 smooth octave
Old 07-19-08, 07:35 PM   #2
Alias: Steven
thewire's Avatar
Loc: Midwest
User: #9828
Since: Jun 2007
  thewire is offline
Re: My First Measurement
Is this is a test of the subwoofer and mains together? What are the crossover or other settings on the system? It looks like your front wall corners could use some broadband absorbtion is my guess by looking at the images.
Old 07-20-08, 06:30 AM   #3
Alias: brucek
User: #6
  brucek is offline
Looks fine.
A few tips:
1- Use LOG mode rather than LIN mode for the waterfall so it won't truncate the plot, and it will match the response plots.
2- Use a horizontal of 15Hz-200Hz graph axis for your response plots.
3- Don't use smoothing on subwoofer plots. It's use should be limited to full range measures where comb filtering may be a problem.
4- Use the AUX or CD input to your receiver with the crossover set as usual and the receiver in stereo mode, with the mains disconnected. This will offer the subwoofer measure a more realistic view through the receivers crossover, that should track the REW target line.
5- Make your measurements at 75dB.
Old 07-20-08, 09:35 AM   #4
Alias: vocal mind
User: #21837
Since: Jun 2008
thewire wrote: View Post
Hi, it's just a subwoofer test using the SW input in 7.1 mode. i guess ill follow bruce recommendation and run a test again.
Old 07-20-08, 09:38 AM   #5
Alias: vocal mind
User: #21837
Since: Jun 2008
brucek wrote: View Post
Looks fine.
A few tips:
Thanks Bruce, ill run the test again. You really mean physically disconnect the mains?
Old 07-20-08, 02:21 PM   #6
Alias: brucek
User: #6
  brucek is offline
Yep, disconnect them with the power off (of course), unless you have separate power amps, there's no other way to do it. It's not a problem - no speaker - no current....
Old 07-20-08, 11:14 PM   #7
Alias: vocal mind
User: #21837
Since: Jun 2008
hi, just measured using bruce suggestion. there is no diff between audessy on or off
audessy eq on
audessy eq on
audessy eq off
audessy eq off
Old 07-21-08, 01:02 AM   #8
bjs
Alias: bjs
Loc: Vancouver, BC
User: #21868
Since: Jun 2008
  bjs is offline
Your waterfall plots aren't displaying correctly so it looks strange. REW has a bug here (in LIN mode). You need to switch to display the waterfall plots in LOG mode to see them correctly.
Old 07-21-08, 02:49 AM   #9
Alias: vocal mind
User: #21837
Since: Jun 2008
bjs wrote: View Post
eh, I can't find the LOG mode settings. Is it the one in the House Curve settings?
Old 07-21-08, 04:04 AM   #10
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
Click the "Freq Axis" button in the toolbar, 3rd from the right. It toggles between linear and logarithmic frequency axis settings for the current graph.
Old 07-21-08, 10:35 PM   #11
Alias: vocal mind
User: #21837
Since: Jun 2008
Hi all, I guess i get my REW setup alright now. However, would this response be rectified using BFD? I am getting one when the paycheck comes.
Old 07-21-08, 11:19 PM   #12
Alias: brucek
User: #6
  brucek is offline
I am quite surprised at how long the low frequencies persist. That peak at 26Hz looks like it wants to go on forever. Amazing. Could you show us the same waterfall with a 600ms time axis.
Tell us about your room and sub location. It must sound very heavy at the bottom end.
Old 07-23-08, 10:28 AM   #13
Alias: vocal mind
User: #21837
Since: Jun 2008
Bruce, my setup is currently in the living room, please take a look at the layout.
I am still planning to install curtain partition between the dining and living after getting the BFD.
Old 07-23-08, 01:37 PM   #14
New Member
Alias: Larry
Loc: Albuquerque
User: #23173
Since: Jul 2008
  LarryD is offline
Where on the screen does it tell you which mode you are in Lin vs LOG. I see how to toggle, but I am not sure which is which. I would assume when the X Axis changes you are in LOG, true?
Old 07-23-08, 01:51 PM   #15
Alias: brucek
User: #6
  brucek is offline
It may be a bit more obvious if you change the horizontal scale to be 15Hz-20,000Hz.
See the difference now in the horizontal divisions?
LOGARITHMIC
LINEAR
Old 07-23-08, 01:54 PM   #16
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
The image of the grid on the Freq Axis button and the x axis grid spacing on the graph show the current setting, when the vertical lines are evenly spaced the axis is linear, when they are closer together at the right it is logarithmic.
Old 07-23-08, 04:24 PM   #17
New Member
Alias: Larry
Loc: Albuquerque
User: #23173
Since: Jul 2008
  LarryD is offline
Thanks
Old 07-24-08, 08:14 PM   #18
Alias: vocal mind
User: #21837
Since: Jun 2008
Hi, this is the waterfall with 600ms time range. The dips and peaks could be due to the room where there is an open space on the left (dining). I was wondering if this can be minimize with a curtain.
Old 07-25-08, 12:36 AM   #19
Alias: vocal mind
User: #21837
Since: Jun 2008
i made some re-arrange
1. place the sub beside the FR.
2. disable audessy EQ - somehow it distorts around 45 to 60 hz
3. manually set the speaker level to 75db and sub to 80 db
4. set the sub to 60hz crossover
5. run test (mains and sub)
6. set PEQ on the subwoofer to cut the 43hz to 57hz peak
7. run test
am i still missing something? i guess the peak on the 20hz to 30hz will be corrected with BFD.
Old 07-25-08, 06:41 AM   #20
Alias: brucek
User: #6
  brucek is offline
Looks good. Yeah, just carry on and see what can be accomplished with a BFD...
Old 07-27-08, 09:23 AM   #21
Alias: vocal mind
User: #21837
Since: Jun 2008
Just got a BFD 1124P and playing with the filters.
Just a quick question, why there is no AUTO EQ Filters for the BOOST on the REW?
Old 07-27-08, 10:51 AM   #22
Alias: brucek
User: #6
  brucek is offline
I don't understand the question. Can you rephrase it?
Old 07-28-08, 08:34 AM   #23
Alias: vocal mind
User: #21837
Since: Jun 2008
eh, i found no filter for boost on this pop-up. the filters are meant for peak only.
Old 07-28-08, 09:37 AM   #24
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is online now
"PK" refers to the type of filter, a parametric biquad often called a "peaking" filter. Whether it has cut or boost is determined by whether the filter's gain is positive or negative. If you assign a filter or two and play with their settings whilst watching the resulting response on the REW graph you will get a feel for what they offer.
measurement
