REW Forum
Setting Up for first measurements
Discuss Setting Up for first measurements in the Equalization | Calibration forum; Setting Up for first measurements Hey everyone, I’m working on setting up a home recording studio and I’d like my room acoustics to be as ...
Views: 376 - Replies: 3
Old 07-26-08, 03:51 PM   #1
New Member
Alias: Shaker78
Loc: Canada
User: #20725
Since: May 2008
  Shaker78 is offline
Hey everyone,
I’m working on setting up a home recording studio and I’d like my room acoustics to be as good as possible.
From what I’ve been reading, it seems I would be better off using a CM-140/150 calibration mic from Galaxy Audio rather than the Radio Shack one, since it covers a wider range of frequencies.
Also, in one of the post on the forum I read:
“The calibration file will only be for the lower end response from 10Hz to about 100Hz where C-Weighting will then take over. The calibration is in no way exact or guaranteed accurate... this is for hobby use only and should not be used professionally.”
How concerned should I be about that? I intend to use my home recording studio to professional ends, so I’m wondering how this will affect readings.
On the Galaxy Audio website, there is the CM-200, which is a Calibrator. I haven’t seen this mentioned on the forums. Has anyone tried it to get a more accurate calibration? Is it any good?
Another thing I’m not sure about, is the use of a Behringer Feedback Destroyer. For a home recording studio I don’t think this is wise to use, am I correct?
That’s all the questions I have for now, thanks!
-=Shaker
Old 07-26-08, 04:26 PM   #2
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: Setting Up for first measurements
I can answer the last question. If your studio is going to have a subwoofer, you'll want a dedicated BFD to smooth its room response. Otherwise, you'll be manipulating your bass tracks to compensate for lower-frequency peaks and valleys you may have. When you play back your mixes on other systems, you'll probably find the bass doesn't sound good.
Old 07-26-08, 04:32 PM   #3
Alias: brucek
User: #6
  brucek is offline
Yeah, the CM-140 is a good value for full range measurements. The Radio Shack meters aren't reliable enough to use past ~3KHz.
You shouldn't be concerned. This is a disclaimer we use to ensure someone doesn't get crazy about the accuracy to the last decimal. You can move a microphone a few inches and create a bigger difference than the cal file.......
A calibrator is to set the absolute output level of a microphone/meter. So when it says at 1KHz that it's 75dBSPL, you know it's absolutely 75dBSPL. This is not required in relative measurements.
Depends. If you use a sub when you're mixing, what happens if your studio has a +20dB peak at 50Hz? Personally, I think your best bet is to use REW to get as flat a response as possible at the listening mixing seat and avoid EQ....
Old 07-27-08, 05:33 PM   #4
New Member
Alias: Shaker78
Loc: Canada
User: #20725
Since: May 2008
  Shaker78 is offline
Thank you both for the quick response! This clarifies things a bit more
I don't have a subwoofer as of yet, am planning to get one in the next few weeks. I guess I'll go ahead and make the initial mesurements without the sub first, see how flat a response I can get. Then add the sub and see how it affects the room.
I'm looking forward to it!
Thanks again,
--=Shaker.
measurements, setting
