| REW Forum Mic on the cheapDiscuss Mic on the cheap in the Equalization | Calibration forum; Mic on the cheap musiciansfriend / product?sku=275560X <----- search by the 275560X in the "keyword or item #"
How do you think this one ... |
Views: 375 - Replies: 4
| | #2 | ||||
| Re: Mic on the cheap That looks like a rebranded ECM8000, but I don't know for sure. You could try it with the cal file here, but chances are it is different and you will have to get a calibration done (not a bad thing for any microphone). | ||||
| | #3 | ||||
| Re: Mic on the cheap You can take advantage of the linear 15Hz to 20kHz frequency response to provide ultimate precise measurements and transparent recordings with your Nady CM100. hmmmm the ECM8000 says the same thing. "Extremely linear frequency response from 15Hz to 20kHz" | ||||
| | #4 | ||||
| Re: Mic on the cheap You might want to see the thread on the Real Traps room mic comparison test in the Mics/Calibration Forum. Regards, Wayne | ||||
