REW Forum
BW Oct = BW/60?
Discuss BW Oct = BW/60? in the Equalization | Calibration forum; BW Oct = BW/60? Sorry for the dumb question: could Wayne or somebody please confirm that these two are indeed the same? I was ...
Views: 294 - Replies: 2
Old 08-04-08, 09:44 PM   #1
Alias: zilbenz
Loc: Orange County, California
User: #22950
Since: Jul 2008
  zilbenz is offline
BW Oct = BW/60?
I was trying to follow Wayne's "Tips for Those Who Use REW's Auto-equalizing function" wherein we're advised to drop "useless filters" such as those with "say 4/60 or less and only 2-b dB gain reduction." There Wayne also discussed the BW/60 conversion to other unit
I came up with filters whose BW Oct values are less than 1. Should I drop these?
What if it's the only filter that REW recommend?
I think this present version 4.11 of REW automatic drops filters if less than 2 dB, correct?
Thank you in advance.
Chris
Old 08-04-08, 10:15 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: BW Oct = BW/60?
A filter with a bandwidth of 1 octave is huge (BW Oct=1). You would certainly not remove any filters that are near that size.
The easiest thing for you to do is play around with the filters in REW to get a feel for the sizes.
Start REW and select either the BFD (which offers its filters in BW/60) or the FBQ (which offers its filters in BW Oct) and then select the EQ filters button and simply enter some filters with some cut or gain and watch them on the screen while you play with the bandwidth. You'll understand it once you do this...
The advice is to not use ridiculously small filters that have no real effect.
Old 08-05-08, 06:06 PM   #3
Alias: zilbenz
User: #22950
Since: Jul 2008
  zilbenz is offline
Re: BW Oct = BW/60?
Thank you for the quick answer.
Chris
bw/60?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332
