EQ subs with mains running full range - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 05-27-15, 12:07 AM Thread Starter
brandon
in the past I've always ran my 2ch fronts crossed over at around 80hz then use REW and my BFD to get a nice flat in room response. If I were to grab a preamp without the ability to cross over my mains and run them full range,, how difficult would it be to get a decent room response? Phase and cancellations will likely be tough to overcome right?
I just can't decide if the better sound quality of a different preamp is more or less beneficial than my current preamp that has crossover options???
bigbwb is offline
post #2 of 7 Old 05-27-15, 11:53 AM
HTS Moderator
Lumen's Avatar
Lou
Re: EQ subs with mains running full range
You don't mention brands or model numbers, so I'll compile a generic reply:
Answering your last question first, I think any benefits of a "better" sounding preamp will be lost along with the crossover function. Assuming your current preamp is capable of amplifying source signals without significant distortion, is a new one really better, or just different? Any preamp differences that do exist will be small. Differences with and without crossover tuning will be huge.
How difficult it is to get decent response will depend on how much time you're willing to spend with speaker/sub positioning. Without crossovers, in-room response will change, as will relative phase/timing between speakers and subs. As you probably already know, bass will be the hardest to tame. Reinforcements can be pulled-down with EQ, but cancellations will need trapping. Then again, even the best traps are only good down to 50Hz or so. The upside is that we're not that sensitive to narrow gaps in low frequencies, especially if the sweet spot is located away from them.
How far you want to take tuning depends on your priorities and hearing acuity. Irregular response can cause instruments to change size/location within the sound field. Very noticeable from the sweet spot. Not so much from the kitchen. Do your subs have any built in PEQ or crossover capability (speaker-level connection) that could substitute for the BFD and preamp functions, respectively?
I try to be as good as my dog thinks I am
Lumen is offline
post #3 of 7 Old 05-27-15, 12:46 PM Thread Starter
brandon
Sorry I should have been more specific.....
Current preamp parasound P5
Amp parasound A21 for fronts
Yamaha CX-A5000 for HT
Out,aw 7 ch amp for all speakers except fronts
Ascend acoustics towers with RaAL
Dual 15" Rythmik subs
Looking at parasound JC2 BP preamp
bigbwb is offline
post #4 of 7 Old 05-27-15, 01:03 PM
tonyvdb's Avatar
Tony
If you dont have a crossover how are you getting the LFE .1 channel? if your thinking that using the High level inputs on the sub and running the mains full range is a good choice it is not as there truly is way to much information below 30Hz for mains to handle in movie soundtracks.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 7 Old 05-27-15, 01:37 PM Thread Starter
brandon
tonyvdb wrote: View Post
Currently the yamaha has sub outputs run through the P5 in HT bypass mode allowing the LFE signal to get to my subs. I do not use high level inputs.
bigbwb is offline
post #6 of 7 Old 05-27-15, 10:42 PM Thread Starter
brandon
BlueRockinLou wrote: View Post
Thank you for the detailed reply. I'm leaning towards sticking with my current preamp or one with XO/bass management. As you said, I will likely lose ground rather than gain by giving up the XO ability.
bigbwb is offline
post #7 of 7 Old 05-28-15, 08:07 AM
HTS Moderator
Lumen's Avatar
Lou
You're welcome, Brandon. Very nice preamps, by the way. You might want to look into room correction using a miniDSP DDRC-22A. Gains realized through room correction and/or acoustical treatment will trounce any gains seen through the upgrade you're considering. You'd want to stick with the analog version to avoid a last-in-chain A/D-D/A conversion step. The analog version offers similar performance to miniDSP's exceptional digital model DDRC-22D reviewed here. I glanced at prices and found that the roughly $900 miniDSP unit could potentially save you a lot of money.
Lumen is offline
eq , full , mains , range , running , subs
