Using 5.11 on Windows 7 x64.
- Start REW. It automatically loads with last saved preferences, including Soundcard Output and Input sections, as expected.
- Open SPL tool/meter
- Red button is grayed out. Mousing over top section of meter says "This SPL reading is not valid unitl it is calibrated against an external SPL meter reading". Even though it was loaded at startup with a UMIK-1 calibration file that has SENS data. Seems something is not right here.
- Click on Calibrate on SPL meter and says "Please select the audio input for the SPL meter" - even though its already selected (because that's how preferences were left after last running REW). Seems something is not right here.
- Go to Preferences->Soundcard. Everything looks as expected. Mic/meter tab shows proper calibration file.
- Change Input from "UMIK-1 Gain 18 dB 1" to "UMIK-1 Gain 18 dB 2" (second choice in dropdown). This then "wakes up" the SPL meter and the red button becomes red instead of gray.
- Just as a santity check, click Calibrate on SPL meter. This time says its not required because sensitity data is in calibration file (as expected).
- Switch back to "UMIK-1 Gain 18 dB 1" option on input.
- Everything fine after that.
Is this a bug? I'm using HDMI with ASIO4ALL v2 with UMIK-1 mic.
Thank you.
Thank you.
