| REW Forum first favorDiscuss first favor in the Equalization | Calibration forum; first favor salutes to all this is my first one post and hopes makes to understand me since uses a translator therefore ... |
Views: 357 - Replies: 14
| first favor salutes to all this is my first one post and hopes makes to understand me since uses a translator therefore does not speak l' English the question was, which audio card advised in order to make optimal measures to me with REQ? my computer is amd 2,2 ghz I have bought also ecm 8000, would go the mic800 well? thanks and salutes still | ||||
| | #2 | |||||
| Re: first favor Welcome to the forum ![]() Quote:
| | #5 | ||||
| Re: first favor The USB EMU 404 is fine, but a bit of overkill for simple REW measurements. You don't require a soundcard that good. But, it does have a mic preamp, so you wouldn't have to purchase one of those. Avoid the Mic 800 if you get a preamp, use the XENYX 802 instead... brucek | ||||
| | #9 | ||||
| Re: first favor the rows I succeed to unload it but it turns out of dimension of 45,5 kb and installed on rew it says to me that c' it is error if the problem remains can ask to send it for mail? annacamilla. | ||||
| | #10 | ||||
| Re: first favor The file is valid that I posted in my thread above. Follow these instruction and it will work. ------------------------------------------------------------------------------- Left click the link, as shown below. ![]() ------------------------------------------------------------------------------- Left click Save on the download popup, as shown below. ![]() ------------------------------------------------------------------------------- Select the location in your computer to save the file, as shown below. ![]() ------------------------------------------------------------------------------- Download complete box will show the job is done. Left click Close, as shown below. ![]() ------------------------------------------------------------------------------- Start REW. Select Settings screen. Select Meter tab. Left click Browse and select the directory where the file is stored in your computer, as shown below. ![]() ------------------------------------------------------------------------------- You will see the file is loaded, as shown below. ![]() ------------------------------------------------------------------------------- brucek | ||||
| | #12 | ||||
| Re: first favor | ||||
| | #13 | ||||
| Re: first favor Or maybe try and copy then past then into a text program such as notepad, then save as newecm.cal. The file size should be like this and not 45,5 kb. ![]() 5.00 -24.79 6.30 -16.22 8.00 -12.54 10.00 -9.23 12.50 -6.64 16.00 -4.68 19.95 -3.09 25.12 -2.08 31.62 -1.30 39.81 -0.83 50.12 -0.41 63.10 -0.14 79.43 0.00 100.00 0.15 125.89 0.22 158.49 0.22 199.53 0.26 251.19 0.26 316.23 0.26 398.11 0.22 501.19 0.20 630.96 0.14 794.33 0.07 1000.00 0.00 1258.93 -0.07 1584.89 -0.13 1995.26 -0.23 2511.89 -0.27 3162.28 -0.13 3981.07 -0.22 5011.87 -0.30 6309.57 -0.25 7943.28 -0.17 10000.00 -0.15 12589.25 -3.77 15848.93 -7.48 19952.6 -9.01 | ||||
