REW Forum
which way to point the mic?
Discuss which way to point the mic? in the Equalization | Calibration forum; which way to point the mic? After struggles, I've got a working machine to use with REW. I also have a Mitey Mike II from Old ...
Views: 441 - Replies: 7
Old 08-15-08, 09:15 PM   #1
Alias: g3kko
Loc: Green Bay-ish, WI
User: #1457
  g3kko is offline
I also have a Mitey Mike II from Old Colony (with .cal). It's omnidirectional and I get that for subs it really doesn't matter which way you point it. But if I'm doing full-range system measurements, which way should the mic be pointed?
Thanks!
Old 08-15-08, 09:49 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: which way to point the mic?
If your only testing your mains/sub then pointing the mic at a 45o angle up towards the ceiling facing the front/center is the best but if your dong a full surround system straight up at the ceiling at ear level is going to give you the best results.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 08-15-08, 10:06 PM   #3
Alias: g3kko
User: #1457
  g3kko is offline
tonyvdb wrote: View Post
I suppose I can expect some top end roll-off pointed at the ceiling, eh?
I'm very curious to measure the whole system, speaker by speaker. I want to see what my receiver's calibration / PEQ really brings to the table.
Old 08-15-08, 10:15 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
You have to remember that even your ear is not hearing sound directly on as they are pointed to the side, a mic works in the same way and thus should not be pointed directly at the speakers. Your room response is as much a part of the sound you hear and that is why you should not point it directly at the speakers.
The proper way to even hold a mic is not to point it directly at the mouth but to speak or sing across it thus giving you better sound.
Home theater:
Two Channel system:
My Webpage
Old 08-15-08, 10:21 PM   #5
Alias: g3kko
User: #1457
  g3kko is offline
But when I do individual driver tests, I do them very much nearfield, with the mic pointed perpendicular to the cone / dome. I think that's what caused me the confusion.
Old 08-15-08, 10:30 PM   #6
Alias: Bob
Loc: Shueyville, Iowa
User: #25
  bobgpsr is offline
IMHO, far-field (sweet spot) point it up.
Near-field (close mic'ing of an individual speaker driver response) point it straight at it.
Old 08-15-08, 10:38 PM   #7
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Yes, as Bob says close up you want to point it at the driver, my misunderstanding.
Home theater:
Two Channel system:
My Webpage
Old 08-18-08, 12:46 AM   #8
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is online now
It all depends on what you're trying to measure and glean from the measurement.
So really I should ask, what practical improvement to the system are you planning to make after taking the measurement? Or what kind of issues are you trying to track down?
Do you want the anechoic frequency response of each speaker? A good analysis of the reflections in the room? Distortion?
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
mic?, point
