| REW Forum calibration done now how to integrate with mainsDiscuss calibration done now how to integrate with mains in the Equalization | Calibration forum; calibration done now how to integrate with mains Good evening
i have completed my REW alibration today al in all 6 filters to set here is a graph ... |
Views: 865 - Replies: 20
| calibration done now how to integrate with mains Good evening i have completed my REW alibration today al in all 6 filters to set here is a graph of my calibration Now the question how do i proceed for main speakers integration with the sub i am a bit confuse on the procedure for that one Alain | ||||
| | #2 | |||||
| Re: calibration done now how to integrate with mains Surprising how good the response is below 80Hz. In fact looks like you didn't even use a filter below 90Hz. But above 80Hz (which I presume is your crossover frequency) it appears the crossover isn't filtering the signal very well. It looks like you had the mains on? What are your thoughts on this? Quote:
brucek | |||||
| | #3 | ||||
| Re: calibration done now how to integrate with mains [QUOTE=brucek;9383]Surprising how good the response is below 80Hz. In fact looks like you didn't even use a filter below 90Hz. But above 80Hz (which I presume is your crossover frequency) it appears the crossover isn't filtering the signal very well. It looks like you had the mains on? What are your thoughts on this? i had disconnected the 3 front mains but because my avr is located in an AV audio center it is proving a real challenge to disconnect the rear so i guess the rs meter picked them up during the sweep ..... | ||||
| | #4 | |||||
| Re: calibration done now how to integrate with mains [QUOTE=apilon;9385] Quote:
Bruce here is my sweep with mains on now when i did the first sweep with front mains disconnected i did not applied any trace smoothing and rew found over 16 peeks but after optimization 6 were applied as follow 1. frq 162 2. frq 198 3. frq 142.5 8. frq 186 10. 128.5 11. 91.00 after main integration and optimization rew applied 5 filters 1. 125 2. 118.8 3. 113.8 4. 106.2 5. 92.00 now what do i do with this do ireplace filter 1 to 3 with te new data and add the ones not setup or do i just add the one not currently setup Alain | |||||
| | #5 | ||||||
| Re: calibration done now how to integrate with mains Quote:
I really feel your sub is not turned up high enough in relation to your mains. Turn it up a bit and remeasure at 80dB - you're measuring a bit low also on your REW setup. brucek | ||||||
| | #6 | ||||
| Re: calibration done now how to integrate with mains [QUOTE=brucek;9387]Why not just select STEREO on your receiver, then only the mains need to be disconnected. Why do you have multi-channel turned on? by defaut the avr635 set up the tape input as logic 7 and it did not cross my mind to change it to stereo That's really up to you. Once you did your sub+mains raw sweep and re-checked the boxes to turn your filters back on, you can modify the existing filters or add extras if necessary until the REW graph looks good. Then enter that into the BFD.. I really feel your sub is not turned up high enough in relation to your mains. Turn it up a bit and remeasure at 80dB - you're measuring a bit low also on your REW setup. what i did was to calibrate the mains and sub using EZ-EQ on the AVR635 which tueed down my subs (i have 2) by -9db and i did not check with the RS meter after to see if everything was fine in term of DB as i ave read on many HT forum that the EZ EQ portion of the AVR635 is doing a wonderful job ..i will crank up the sub a bit redo the EZ EQ and then run REW again to see if things will get better . Unlss you think that it would be better to jst calibrate all the mains and sub at 75db or 85db then run REW applied filters than run EZ EQ | ||||
| | #7 | |||||
brucek | |||||
| | #8 | |||||
| | #9 | ||||
| Re: calibration done now how to integrate with mains Sub is certainly too low, for your desired house curve it needs to come up about 10dB, you also need filters at the various peaks indicated below - REW isn't suggesting any because the sub level is too low for the peaks to show above the target curve. | ||||
| | #10 | |||||
i then proceeded to the sub calibration with REW with mains off this time and this is the graph i got You probably gonna tell me that the sub is still low but if i raise the sub volume it is getting way too loud ...so loud i can pinpoint where it is located anyhow 6 frequencies to set from 445 to 500 i then reconnected the mains played music and a movie demo and looks fine althought sub a bit loud i then proceeded to main integration with sub and this is what i got 5 frequencies to set from 122.5 to 166 wat i did is set up these one on filter 5 so i can alternate between the 2 and see which one seems to do the better job Any thoughts idea are welcome Alain | |||||
| | #11 | ||||||
And yes, when using REW, you must set the measurement level at the target level so REW can suggest filters. Your sub is set so low, REW will never recommend anything below 80Hz. Quote:
brucek | ||||||
| | #12 | ||||
| Re: calibration done now how to integrate with mains [QUOTE=brucek;9438]I don't doubt you can localize it. It looks like your crossover isn't working. Your sub isn't rolling off at all. Look at the target and your signal above 80Hz...? I followed some instruction from another HT forum for setting up my sub volume at half point phase a zero and crossover at the highest settings then set the crossover point in the receiver at 80 And yes, when using REW, you must set the measurement level at the target level so REW can suggest filters. Your sub is set so low, REW will never recommend anything below 80Hz. ok ...so there is someting that i am not doing right here then because when i followed the instructions for measurement it said set target level so i press set target level button it came up with a target of 75db then i pressed atomatic measurement so am missing something between setting up target level and automatic measurement??? I think i need more explanation on how to do this right Sorry, I don't understand this. We're measuring from 10Hz to 200Hz. What is 445 to 500? i just realized thatmy peak range is at 10 to 500 | ||||
| | #13 | ||||
| Re: calibration done now how to integrate with mains one question that just pop my mind i set the spl at 75db as per the help file instruction but when i do the rew spl calibration which figure do i enter in the box before pressing done the reading of my external spl or the one that shows in the rew db spl box on the left Alain | ||||
| | #14 | ||||
| Re: calibration done now how to integrate with mains Enter the reading on the external SPL meter | ||||
| | #15 | |||||
| | #16 | ||||||
Personally, I like to set up the measurement level to 80dB (even though REW says 75dB), because it centers the needle on the RS SPL meter. In fact, when you read the little pop-up when doing the Input Volume setup, you'll see REW alludes that 80dB is better for the RS meter (even though it didn't in the Measurement Level pop-up. At a 80dB setting on an RS Meter, you can hardly read 75dB accurately. 80dB is centered. See the pic below: ![]() So, set everything to 80dB. Then of course if you add a large house curve, again the level may be too low. At that point I have simply manually lowered my target level after the Automatic Measurement to get more of my response above the target line, so REW will recommend more filters for me. ![]() brucek | ||||||
| | #17 | |||||
| | #18 | |||||
John Thanks for the patience and the help just so i understand once i set the target level , are you saying that i should press the calibrate button to recalibrate the SPL prior to take measurement??? | |||||
| | #19 | ||||||
| | #20 | ||||
| Re: calibration done now how to integrate with mains You only need to do the calibration once, it is then OK for all subsequent measurements unless you change the input volume setting. | ||||
| | #21 | ||||||
If the subwoofer itself has an integral crossover, it should be bypassed or set to maximum. brucek | ||||||
