REW ForumDiscuss My graphs - advice appreciated in the Equalization | Calibration forum; My graphs - advice appreciated Any advice appreciated. If you think I should do something different and remeasure, I can do that. This is the ... |
Views: 1071 - Replies: 27
| My graphs - advice appreciated Any advice appreciated. If you think I should do something different and remeasure, I can do that. This is the best location for my sub based on experimentation (front corner for SVS and behind my seat for MBM). Basically, I'm curious if I should equalize and/or get bass traps. SVS PB10 HSU MBM 12 Treatments for reflection points (no bass traps) I calibrated MBM and SVS using receiver test tone Both subs (no mains), 80 receiver crossover; SVS crossed at 50hz ![]() Both subs (no mains), 100 receiver crossover; SVS crossed at 50hz ![]() Both subs (no mains), 150 receiver crossover; SVS crossed at 50hz ![]() Last edited by union1411; 08-27-08 at 11:44 PM.. | ||||
| | #3 | ||||
| Re: My graphs - advice appreciated These two graphs are SVS only (no MBM or mains) 80 hz, no internal crossover ![]() 100hz, no internal crossover ![]() sorry, didn't do a 150hz with svs only waterfall of svs only crossed at 100 hz ![]() vs. waterfall of both subs crossed at 100 hz ![]() Last edited by union1411; 08-28-08 at 12:06 AM.. | ||||
| | #4 | ||||
| Re: My graphs - advice appreciated my dedicated HT room it's only 11 x9 feet. but it's my baby (ignore my DYI screen and speaker heights and black grill on my gray svs, still fiddling around/experimenting with stuff)![]() ![]() Last edited by union1411; 08-27-08 at 11:47 PM.. | ||||
| | #6 | ||||
| Re: My graphs - advice appreciated so, i'm wondering if i should keep the MBM-12 or if I should just go with a better sub (and get rid of the SVS) and return the MBM. I've heard an Epik sub and it sounded much better than my SVS (in a worse room too). So I'm looking at the Epik Castle and I'm interested in the MFW-15 as well. But not sure if one of those subs would be better than the SVS/MBM-12 combo I have. I do have a small room, so not sure how much the nearfield placement benefits of the MBM-12 come into play - I'm sitting only about 6 feet from the from the front of my SVS, so I think the tactile benefits (and the benefits of being close to midbass reproduction) might be there if I just go with one great sub instead of the combo. I don't know. It's time consuming and expensive to buy/return subs to test them out because of the shipping costs and lag between ordering and receiving (though HSU was superfast). red: svs with mbm 80 hz xo on receiver, 50hz xo on SVS blue: svs no internal crossover, 80 hz on receiver ![]() red: svs with mbm 100 hz xo on receiver, 50hz xo on SVS blue: svs no internal crossover, 100 hz on receiver ![]() decisions, decisions Last edited by union1411; 08-28-08 at 01:37 AM.. | ||||
| | #8 | ||||
| Re: My graphs - advice appreciated I know how you feel some times. It takes awhile for the experts to chime in. As for keeping the MBM. We can't answer that for you. Looking at your graph of just the SVS, you may not need one. Have you looked at applying Wayne's hard knee curve to your graph's? Do you have any type of BFD? There is a good chance you do not need the MBM. It will take some tweaking with a BFD to get there. If you are not interested in pursing/applying a BFD, then keep the MBM. It is obviously helping the range it was designed to. | ||||
| | #9 | ||||
| Re: My graphs - advice appreciated Well said, weverb... union1411, I would think that your current set-up sounds amazing in your space.... | ||||
| | #10 | |||||
| Re: My graphs - advice appreciated Quote:
As for keeping the MBM. We can't answer that for you. Looking at your graph of just the SVS, you may not need one. brucek | |||||
