REW Forum
Sound card for a laptop?
Discuss Sound card for a laptop? in the Equalization | Calibration forum; Sound card for a laptop? Hi, I have just bought a laptop to use with REW in my HT but am not sure about the ...
Views: 2045 - Replies: 17
Old 08-16-06, 05:36 AM   #1
Alias: Tim
Loc: Australia
User: #1326
Since: Jun 2006
  Timoxx4 is offline
Hi,
I have just bought a laptop to use with REW in my HT but am not sure about the soundcard issue and what will work with REW.
Looking at an external USB one but i might have to upgrade the laptops USB ports from 1.1 to 2.0 ?
What is everyone here using with there laptops?
If it helps i got an ACER Travelmate 270.
Looking at these what would be best for working with REW ? http://au.creative.com/products/welc...?category=244&
Thanks,
Tim.
Old 08-16-06, 07:38 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Sound card for a laptop?
Many here use the Creative Soundblaster MP3+ USB Sound Card. It's inexpensive and does the job.
Old 08-16-06, 08:11 AM   #3
Alias: Tim
Loc: Australia
User: #1326
Since: Jun 2006
  Timoxx4 is offline
Only problem is there are none about here in Australia anymore I guess i could import one from the US but it would cost the same as a new one to get it here and i would just rather a new model.
So what would be a sutiable recent model one do you think?
Thanks,
Tim.
Old 08-16-06, 09:55 AM   #4
Alias: brucek
User: #6
  brucek is offline
Just about any soundcard that is full duplex and had line-in and line-out connections will work. Any inadequacies are compensated for in REW after you carry out a soundcard calibration (the first part of REW setup).
A more recent card would be the Soundblaster Live! 24-bit USB. It works fine with REW. We have had members use it successfully with USB1.1 as I remember....
Old 08-17-06, 05:24 AM   #5
Alias: Tim
Loc: Australia
User: #1326
Since: Jun 2006
  Timoxx4 is offline
Ok. How about this ? http://www.rolandcorp.com.au/default.aspx?prd=387
It has MIDI in/out too so would that be able to interface with the Behringer for EQ setup ?
I had a quick look at that Sound Blaster one but it dosent seem to have RCA in/out connectors dose it? The instructions for REW say the mic/headphone in/out connectore are not good enough what ever that means?
Old 08-17-06, 07:02 AM   #6
Alias: Chrisbee
Chrisbee's Avatar
User: #33
  Chrisbee is offline
Timoxx4 wrote: View Post
The Soundblaster Live! uses mini stereo jacks.
What the REW instructions are telling you is that you must use the Line In and Speaker out sockets NOT the microhone & headphone sockets.
Old 08-17-06, 07:57 AM   #7
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Headphone outputs can be used, no problem with them, but typical mic inputs are not suitable for connecting line sources (like the RS SPL meter) because they have too much gain (mic signals are much smaller than line level signals), are too noisy electrically (partly due to their higher gain), often carry a 5V DC signal to supply a mic and in at least some cases have a limited frequency range (probably to help with their noise problems).
Old 08-17-06, 08:10 AM   #8
Alias: Tim
Loc: Australia
User: #1326
Since: Jun 2006
  Timoxx4 is offline
Ahh i see. Well that makes things easyer.
But on another note while i was searching for sound cards i happend appon this
http://www.rolandus.com/products/pro...8&ParentId=114
How about that for an all in one soultion It has Phantom power XLR connectors so you can plug in the ECM8000 mic. It has MIDI in and out. And has RCA line in/out and full duplex support.
Yes its more expencive than the sound blaster but its better quality by far and you dont need to buy a seperate mixer thing with Phantom power supply for the ECM8000 and you also dont need to buy a MIDM interface. Its all in one little unit that runs off the USB and dosent even need an external power supply.
But will it work with REW ????
Old 08-17-06, 08:21 AM   #9
Alias: brucek
User: #6
  brucek is offline
Looks like it would be fine.......
Old 08-17-06, 10:35 AM   #10
plincoln
Inactive
Alias:
User: #
Posts: n/a
brucek wrote: View Post
That's what I use as well. Got a good on a refurb deal straight from creative.
Old 08-17-06, 08:05 PM   #11
Alias: Tim
Loc: Australia
User: #1326
Since: Jun 2006
  Timoxx4 is offline
Fantastic I just might get one.
Thanks guys
Old 09-15-06, 01:57 AM   #12
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
Thanks,
Tim.
That card is sold in Aus as the 'Soundblaster Digital Music LX', I saw one at IT warehouse during the week, $100 I think.
I just purchased a Behringer U-control UCA-202 off e-bay for $60, haven't tried it yet though.
http://www.behringer.com/UCA202/index.cfm?lang=ENG
Harry.
Old 09-15-06, 10:31 AM   #13
Alias: Mitch
Loc: Naperville, Illinois
User: #2469
Since: Sep 2006
  Mitch G is offline
Hakka wrote: View Post
<snip>
Harry.
That Behringer unit looks like it would be perfect at a very competitive price.
I bought a refurb Creative Live! unit for $35 (US) shipped, the Behringer MSRP is $35 (US) *new* - which means it could probably be found for less. And I could probably find it at a local guitar shop. Furthermore, since it uses RCA connectors, that saves a couple of bucks and the trouble of picking up RCA-3.5mm jack adapters.
I hope it works well with REW because it seems to be just what the doctor (or wizard) ordered.
Mitch
Old 09-15-06, 08:04 PM   #14
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
I set it up last night and it worked fine. There is no adjustment for the line in volume but it was spot on anyway. I ran the soundcard calibration and the graph was very flat with a small roll off below 20hz.
Only hiccup I had was REW was muting the speaker output on the card, they call the line output 'speaker' and the line input 'mic' in the device menus.
The REW program is great, last time I calibrated I did it manually, it took a whole weekend and I still didn't get the result I wanted. I spent about 45 minutes last night and I now have a perfectly shaped sub curve.
Harry.
Old 09-15-06, 08:52 PM   #15
Alias: Tim
Loc: Australia
User: #1326
Since: Jun 2006
  Timoxx4 is offline
Thats cool.
Now you just got to do all the other speakers lol
Old 09-15-06, 11:05 PM   #16
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
Yep, will start testing the other 7 speakers tonight to find out the best placement.
Old 09-17-06, 06:39 PM   #17
jeffbridges
Inactive
Alias:
User: #
Posts: n/a
I 2nd the Creative Soundblaster MP3+ USB. I had another box that required 20 bucks worthr of 3.5mm to rca converters!
Old 10-04-06, 10:38 PM   #18
Bronze Supporter
Alias: jack
basementjack's Avatar
Loc: Chicago Suburbs, IL USA
User: #2649
Since: Sep 2006
  basementjack is offline
Not sure if it's available down in Aus, but the ADS instant music usb sound card works great - no need for drivers, has stereo RCA in and out, and has optical digital in and out.
Here in the us it's available for about $40 from tigerdirect.com
