| REW Forum Slaughter House HT REW ResultsDiscuss Slaughter House HT REW Results in the Equalization | Calibration forum; Slaughter House HT REW Results I decided to start over as i discovered that I had not loaded my calibration file for my sound meter. ... |
Views: 436 - Replies: 15
| Slaughter House HT REW Results I decided to start over as i discovered that I had not loaded my calibration file for my sound meter. So here goes. Polk 8" By itself in the North East corner ![]() DCM 10" by itself firing into the South East corner ![]() Here is the polk and the DCM together ![]() | ||||
| | #2 | ||||
| Re: Slaughter House HT REW Results And here is everything including the mains I may need to re-calibrate my YPO on my receiver again and take another reading. ![]() | ||||
| | #3 | ||||
| Re: Slaughter House HT REW Results I calibrated YPO on the receiver and here is what I have now full system (subs+mains) ![]() | ||||
| | #4 | |||||
| Re: Slaughter House HT REW Results Quote:
![]() I'm sure you have a parametric equalizer on your receiver ... try increasing the frequency response for the sub (I think the lowest is 30Hz), increase that frequency a couple of db and see if that changes the response in the lows (30Hz-40Hz range, that's what I did with mine) ![]() | |||||
| | #5 | ||||
| Re: Slaughter House HT REW Results Not sure I can do that, here is the manual for my receiver, page 90 and 91 is the area for the parametric EQ and the only thing i can do it seems is to lower the db on the LFE but I can adjust all but the sub on the EQ. http://www.yamaha.com/yamahavgn/Docu...X-V663_U-1.pdf You have to register to open these, goofs! | ||||
| | #6 | |||||||
)You're right ... according to the manual: Quote:
![]() EDIT: This is what it says on my manual: Quote:
| | #7 | ||||
| Re: Slaughter House HT REW Results Already did, it does not list the SW as an option only the mains. ![]() | ||||
| | #8 | ||||
| Re: Slaughter House HT REW Results Based on these readings would I greatly benefit from a BFD or should my money got toward a new SVS Sub or base traps/acoustical treatments? | ||||
| | #9 | ||||
| Re: Slaughter House HT REW Results I vote for a newer better sub. No offense, but there's just not much to work with with those 2 small guys and I think you'd get the biggest improvement by getting a more powerful and extended sw. | ||||
| | #10 | |||||
![]() I am talking with the guys over at SVS and more than likely going to pull the trigger on either the PCi-20-39 or the 25-31 they said they can tune to 22hz the height of the sub I don;t think is going to cause me a problem its just the BIG box type I have no place to put it ;-) | |||||
| | #11 | |||||
![]() Don't forget that you still need some accoustic treatment (maybe not for the bass, but for the rest of the system) ... you can work on that later, first get the sub then the next step ![]() | |||||
| | #12 | ||||
| Re: Slaughter House HT REW Results I know, I am risking a "confrontation" when the SVS shows up at the door. That kinda thing I am sure will not go un-noticed. ![]() ![]() | ||||
| | #13 | ||||
| Re: Slaughter House HT REW Results HA! And I just found a NEW BFD 1124 for $60, Found a guy that bought one and discovered later that it was not what he needed and never used it. | ||||
| | #14 | |||||
| Re: Slaughter House HT REW Results You better grab it now before is gone ... remember "Better safe than sorry" ![]() Quote:
(Good excuse, Don't you think??? ) | |||||
| | #15 | ||||
| Re: Slaughter House HT REW Results Hah! That's a good excuse. Either of those SVS's should be a huge step-up from the 2 other subs combined! | ||||
| | #16 | ||||
| Re: Slaughter House HT REW Results I picked up my BFD and this thing is brand new, all the packaging and manuals, even the company sticker ;-) now to figure out where to put it and read up on the docs here on how to use it ;-) for $60 and about $5 worth of gas, I could not turn it down. ![]() | ||||
