REW Forum
first soundcard calibration attempt....thoughts?
Discuss first soundcard calibration attempt....thoughts? in the Equalization | Calibration forum; first soundcard calibration attempt....thoughts? let me start by saying i have no idea what i'm doing. this is my first attempt at calibrating the ...
Views: 399 - Replies: 11
Old 09-11-08, 12:50 AM   #1
Alias: sollars
Loc: Kansas City, Missouri
User: #19719
Since: Apr 2008
  mrsollars is offline
this is my first attempt at calibrating the soundcard on my macbook running leopard.
i have no idea what i'm doing with REW and would love for another mac user running leopard to screen share with me to give me a step by step and teach me to do it on my own. i'm open to any and all suggestions.
thanks guys.
matt
Old 09-11-08, 06:23 PM   #2
Alias: sollars
User: #19719
Since: Apr 2008
Re: first soundcard calibration attempt....thoughts?
i gave you guys a whole 18 hours or so...and nothing. what kind of forum is this.
i'm kidding....but i'm also dying to get my setup ''REW'D'' asap. and i'm on a mac...and that doesn't help i'm sure. i also don't know my from a hole in the ground when it comes to this stuff. (also, not a help)
thanks guys.
matt
Old 09-11-08, 07:01 PM   #3
Alias: TFan
Loc: Palo Alto, CA
User: #25111
Since: Sep 2008
  TheaterFan is offline
Try setting it to 1/3 octave filtering on the left side of the screen and see how it looks.
Old 09-11-08, 07:05 PM   #4
Alias: brucek
User: #6
  brucek is online now
What version of Mac are you using?
Old 09-11-08, 07:10 PM   #5
Alias: sollars
User: #19719
Since: Apr 2008
i don't have it with me right now...i'm at work.
i'll be able to be home at 8pm central (2hours from right now)
i'm using a macbook. Newest Leopard OSX update....2ghz machine.
i also have a 24'' aluminum imac running the most updated leopard as well. (if that helps.)
let me know if any of this helps.
thanks.
matt
ps. i would love to have enough money to fly you out here brucek...and just watch you work....but i mentioned in another thread, i'm a teacher
Old 09-11-08, 07:11 PM   #6
Alias: sollars
User: #19719
Since: Apr 2008
another note....i'm always up for screen sharing and letting somebody show me step by step....another leopard user that is.
thanks
matt
Old 09-11-08, 07:42 PM   #7
Alias: brucek
User: #6
Yeah, I know next to nothing about Macs, so I usually steer clear and let JohnM handle the Mac stuff. Hopefully he'll see your post.
The operating system should be fine, but I have read several posts from people with macbooks having trouble.
Here's a post where the person is using Leopard on a Macbook and shows the exact same graph problems that you are experiencing.
Old 09-11-08, 07:49 PM   #8
Alias: sollars
User: #19719
Since: Apr 2008
yeah i saw that. i would LOOOVE for johnm to jump in here....he does seem to know his stuff when it comes to macs . is he a user? does he have leopard? a screen share with him would be incredible.
thanks brucek.
matt
Old 09-11-08, 11:04 PM   #9
Alias: brucek
User: #6
He is the author of REW...........
Old 09-11-08, 11:12 PM   #10
Alias: sollars
User: #19719
Since: Apr 2008
i meant a mac user.
also...will you check my pb13-ultra thread. i bet you can answer it.
it's in the setup forum i believe.
matt
Old 09-12-08, 02:11 PM   #11
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Hello Matt,
REW currently only works on Intel Macs. I'm overseas on business but this post has good instructions for Mac setup: http://www.hometheatershack.com/foru...-progress.html
Old 09-13-08, 05:05 PM   #12
Alias: sollars
User: #19719
Since: Apr 2008
thanks for the link. quick question.
i have a screen for speaker level.....where i can change the output of all of them. i started with the volume pretty high......then set all to 'level' at 80db. then i went speaker to speaker and adjusted each bar so that they all produced the 80db level.
my question.....what should i be setting my sub to.....how much do i adjust in THAT menu....and where should my ''gain'' knob be? thanks.
matt
attempt....thoughts?, calibration, soundcard
